D-Link 20-Port Gigabit Stackable Smart Managed Switch with 4 x 10G SFP+ Ports
Quicklinx: J7KPWS00 Mfr#: DGS-1530-20/B
Type: Gigabit Ethernet
Ports: 16
Managed: Yes
£252.09 ex VAT
£302.50 inc VAT
The D-Link DGS 1530-20 offers enhanced networking capabilities with a focus on performance and manageability. This switch is equipped with 20 ports and supports 10 Gigabit SFP+ connections, ensuring high-speed data transfer and robust connectivity for various network needs. With features such as IGMP snooping, Quality of Service, and support for VLAN trunking, it enables efficient network management, optimizing data flow and reducing congestion. Designed for rack-mount installation, the switch operates reliably across a wide temperature range, making it suitable for diverse environments. In addition to its extensive capacity for VLAN groups and static ARP entries, the D-Link DGS 1530-20 is stackable, allowing for seamless expansion as network demands grow. With a forwarding performance of 112 Gbps and jumbo frame support, it caters to high bandwidth applications. Security features including RADIUS authentication and TLS 1.2 encryption enhance network integrity, ensuring data is protected. This versatile switch is suitable for businesses seeking to improve their networking infrastructure without compromising on quality.
  • High-performance networking
    With a switching capacity of 80 Gbps and forwarding performance of 112 Gbps, the D-Link DGS 1530-20 efficiently manages data flow, making it ideal for high-traffic networks.
  • Flexible management options
    The switch supports multiple remote management protocols including SNMP and RMON, enabling easy configuration and monitoring of network performance.
  • Extensive port configuration
    Offering 20 ports, this model includes 16 10/100/1000 ports and 4 10 Gigabit SFP+ ports, providing versatile connectivity options to accommodate various devices.
  • Durable and reliable design
    Built to operate in temperatures ranging from -5 °C to 50 °C, the switch ensures stable performance in diverse working environments.
  • Robust security measures
    Equipped with advanced encryption algorithms and authentication methods, this switch protects against unauthorized access and secures network communication.
D-Link DGS 1530-20 - switch - 16 ports - smart - rack-mountable
Switch - 16 ports - smart - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 + 4 x 10 Gigabit SFP+
Performance
Switching capacity: 112 Gbps , Forwarding performance (64-byte packet size): 83.33 Mpps , Stacking bandwidth: 80 Gbps
Packet buffer size: 1.5 MB , MLD groups: 1024 , VLAN groups: 4094 , Static ARP entries: 255
MAC Address Table Size
16K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMP, IGMPv2, IGMPv3, MLD, MLDv2, static IP routing
Remote Management Protocol
SNMP 1, SNMP 2c, SNMP 3, RMON 1, RMON 2
ERPS, MDI, MDI-X, Link Aggregation, STP support, BPDU Filter, Loop Guard, MSTP support, RSTP, Root Guard, flow mirroring, loopback detection, port mirroring, IGMP snooping, GVRP, Private VLAN, VLAN trunking, Voice VLAN, QoS, WDRR, WRED, WRR, CoS, BPDU, DoS, EEE, D-Link DDP, NTP 3, NTP 4, LACP support, store and forward, auto-uplink (auto MDI/MDI-X), half/full duplex mode, 6KV Surge protection
IEEE 802.11d, IEEE 802.11p, IEEE 802.11q, IEEE 802.11s, IEEE 802.11v, IEEE 802.11w, IEEE 802.1AX, IEEE 802.3ab, IEEE 802.3ae, IEEE 802.3az, IEEE 802.3u, IEEE 802.3x, IEEE 802.3z
AC 100-240 V (50/60 Hz)
28 cm x 18 cm x 4.4 cm
2 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
10240 bytes
Max Units In A Stack
9
Routing Protocol
Encryption Algorithm
TLS 1.2
Authentication Method
Secure Shell v.2 (SSH2), RADIUS, TACACS+
Status Indicators
Console, link/activity/speed, power, RPS (Redundant Power Supply)
16 x 1000Base-T RJ-45 , 4 x 1000Base-X SFP+ , 1 x management RJ-45 , 1 x USB 2.0 Type A
Internal power supply
Rack Mounting Kit
Included
MTBF
630,098 hours
BSMI, CB, cUL, EMC, FCC, IC, LVD, RCM, UKCA, VCCI
United Kingdom
28 cm
18 cm
4.4 cm
2 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 16
Managed: Yes
Brand: D-Link
