D-Link 2-Port KVM Switch with built-in Cables
Customer rating: 4.0* (Write a review)
Quicklinx: 36ZSWS00 Mfr#: DKVM-2K
The DKVM-2K 2-port mini KVM switch kit is a cost effective kit for home and office users. This kit allows you to easily control 2 different PCs from a single set of keyboard, mouse, and VGA monitor. It includes a 2-port KVM (Keyboard, Video and Mouse) switch and 2 sets of built-in cables for ready connection to 2 PCs. The switch provides many easy to use features and is perfect for home and small businesses.
D-Link DKVM 2K - KVM switch - 2 ports
Subtype
KVM
Ports
2 x KVM port(s)
KVM Users Qty
1 local user
14 cm x 6.2 cm x 2.8 cm
420 g
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2
Max Resolution
2048 x 1536 @ 72 Hz
Status Indicators
Port status
2 x keyboard (PS/2) , 2 x mouse (PS/2) , 2 x VGA HD-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x VGA HD-15
2 x keyboard / mouse / video cable - 1.8 m
FCC Class B certified, C-Tick
14 cm
6.2 cm
2.8 cm
420 g
0 - 80%
Customer reviews
Write a review for the D-Link 2-Port KVM Switch with built-in Cables here!
Easy Peasey
Reviewed by Rebecca Dittman. Review Posted 21/12/2006
What a brilliant piece of kit! Having bought a new (faster) desktop I still had use for my old one. Having only one screen and an empty bank balance I needed something to link my two destops together. The D-Link KVM switch worked straight out of the box. Simple to install and use. Compact and comes with everything you will need. Thanks D-Link!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Does what it says
Reviewed by Anonymous Review Posted 26/02/2007
I used it to connect a PC and an old Acorn RiscPC to a monitor. I deliberately chose a KVM with s physical switch as well as keyboard activation and this paid off as the RiscPC needs to sense the devices within a second or so of powering on. By pressing the switch on the D-link at the same time as powering on the RiscPC, I could make it work. A minority interest, I accept, but it does the job.
  • Overall 5*
  • Ease of use 4*
Good but not perfect!
Reviewed by Gary Thorpe. Review Posted 10/04/2007
I used this product to connect two desktop PC's at work, one running XP one running ME and it works great, easy switching via the hotkey with only the tiniest of delay. The only problem I have found is the mouse cursor doesn't work on start up of the PC running XP, it needs to be restarted before it gets going, after that everything is a-ok!!
That little niggle aside this is a very good product for the money and I would recomend to anyone wanting to simply run two PC's through one monitor/keyboard/mouse!
  • Overall 5*
  • Ease of use 5*
Read all 7 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
