The answer to expensive, outdated analog CCTV surveillance systems has arrived. When coupled with D-Link's high-resolution and feature rich network cameras or those of other brands, the DNR-326 2-Bay Professional Network Video Recorder (NVR) offers a comprehensive video display, storage, and management solution. D-Link's DNR-326 provides reliable high-quality remote monitoring functionality at a fraction of the cost of conventional surveillance systems.
- D-Link DNR-326 2-Bay Professional Network Video Recorder - standalone DVR - 9 channels
- Standalone DVR - 9 channels - networked
- Compression Format
- MJPEG
- Hard Drive(s) Supported
- Quantity: 2
- 17.9 cm x 14.6 cm x 11.5 cm
- 0.88 kg
- Standalone DVR
- Video Channels
- 9
- MJPEG
- Package Content
- Manual, DVR, software
- Cables Included
- Network cable - 1 pcs.
Security DVR
- Networked
- RAID 5 support, RAID 0 support, RAID 1 support
Hard Drive
- Quantity Supported
- 2
- Interface
- Serial ATA
- DDNS Support
- Web Server
- Network Interfaces
- Ethernet 10Base-T/100Base-TX/1000Base-T
- Supported Protocols
- DHCP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, UPnP, IPv4, PPPoE
- Auto-uplink (auto MDI/MDI-X)
- Network Port
- 10/100/1000Base-T
- 17.9 cm
- 14.6 cm
- 11.5 cm
- 0.88 kg
- 0 °C
- 55 °C
- 5 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
