D-Link 2-Bay Professional Network Video Recorder
Quicklinx: 7ZN0WS00 Mfr#: DNR-326
The answer to expensive, outdated analog CCTV surveillance systems has arrived. When coupled with D-Link's high-resolution and feature rich network cameras or those of other brands, the DNR-326 2-Bay Professional Network Video Recorder (NVR) offers a comprehensive video display, storage, and management solution. D-Link's DNR-326 provides reliable high-quality remote monitoring functionality at a fraction of the cost of conventional surveillance systems.
D-Link DNR-326 2-Bay Professional Network Video Recorder - standalone DVR - 9 channels
Standalone DVR - 9 channels - networked
Compression Format
MJPEG
Hard Drive(s) Supported
Quantity: 2
17.9 cm x 14.6 cm x 11.5 cm
0.88 kg
Standalone DVR
Video Channels
9
Compression Format
MJPEG
Package Content
Manual, DVR, software
Network cable - 1 pcs.
Security DVR
Networked
RAID 5 support, RAID 0 support, RAID 1 support
Hard Drive
Quantity Supported
2
Serial ATA
DDNS Support
Web Server
Network Interfaces
Ethernet 10Base-T/100Base-TX/1000Base-T
Supported Protocols
DHCP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, UPnP, IPv4, PPPoE
Auto-uplink (auto MDI/MDI-X)
Network Port
10/100/1000Base-T
17.9 cm
14.6 cm
11.5 cm
0.88 kg
55 °C
5 - 90% (non-condensing)
7ZN0 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
