D-Link 180W PoE Redundant Power Supply for DGS-1520-28 and DGS-1520
Quicklinx: J7M4WS00 Mfr#: DPS-520
Power Rating: 180watt
£270.58 ex VAT
£324.69 inc VAT
The DPS-520 provides power supply redundancy and resiliency for Power over Ethernet (PoE). It ensures continuous device activity and offers protection against device power supply failures by providing seamless failover for D-Link switches.
  • High flexibility and availability
    The DPS-520 PoE redundant power supply system offers stable, reliable safety features and protection to you network. With a 180W power budget and four ports with PoE power budget, it can actively back up four compatible D-Link switches while using PD power connection box, reducing the redundant power cost per device. In the event of a power supply failure, the redundant power supply unit is immediately triggered, allowing the LAN switch and its connected devices to remain operational.
  • Auto discovery
    Automatically detect PD (powered device) to deliver immediate power.
  • RPS port priority
    Allows the network administrator to define RPS failover policy.
  • Status reporting
    Monitor status and back up a failed switch via web browser.
  • Plug-and-Play
    Simple installation without complex configurations allows convenient management for network administrators.
  • Overcurrent protection
    Automatically provides short-circuit protection to prevent equipment damage caused by high currents.
  • 90W PoE per port
    Offers a 90W power budget per port and a total of 180W for reliable backup power.
D-Link DPS-520 - PoE injector - 180 watt
PoE injector
Power Over Ethernet (PoE)
PoH / PoE
1.15 kg
Input Voltage
AC 100-240 V
Power Capacity
180 watt
Output connectors
4 x RJ-45 90 W
Ethernet 10/100/1000
19.6 cm x 25.7 cm x 5.2 cm
DGS 1520-28, 1520-28MP, 1520-52, 1520-52MP
PoE injector
PoH / PoE
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
4 x RJ-45 90 W
Power Capacity
180 watt
Remote Management Interface
4 x Gigabit LAN - RJ-45 , 1 x management (Gigabit Ethernet) - RJ-45
MTBF
53,858 hours
Overcurrent protection, LED indicators
Plug and Play
50 °C
10 - 90% RH
19.6 cm
25.7 cm
5.2 cm
1.15 kg
D-Link DGS 1520-28, 1520-28MP, 1520-52, 1520-52MP
Brand: D-Link
