The D-Link DMS 1250-18P switch is designed to meet the demands of modern networks while providing reliable and efficient performance. With a maximum switching capacity of 120 Gbps and a packet forwarding rate of 89.29 Mpps, this switch ensures fast data transmission between connected devices. It supports Power over Ethernet (PoE+) with a budget of 240 W, allowing devices such as IP cameras and phones to receive power through the network cable, reducing the need for additional power outlets.
Offering extensive management capabilities, the D-Link DMS 1250-18P features SNMP support for remote monitoring and management, along with various protocols for enhanced network security. Built with features such as VLAN support, IGMP snooping, and port security, this switch helps maintain optimal network performance and security. Its robust design includes environmental resilience with operational temperature ranges between -5°C to 50°C and humidity levels up to 95%, ensuring dependable functionality in diverse environments.
Capacity for data handling
The D-Link DMS 1250-18P switch supports a maximum of 128 IGMP groups, 16 static MAC entries, and 4094 VLAN groups, making it suitable for a wide range of networking applications. -
Security features
Incorporating port security entries and capabilities like DHCP snooping and ARP inspection, this switch helps protect local networks against unauthorized access and attacks. -
Flexible connectivity options
With 18 ports, including PoE+ and 10GBase-X interfaces, this switch provides flexibility in connecting various devices and supports different network speeds. -
Environmental design
Built to operate in temperatures from -5°C to 50°C and a humidity range of 0 to 95%, the switch is designed for stable performance in challenging environments. -
Management
Featuring multiple remote management protocols such as Telnet and RMON, the switch allows for simplified monitoring and configuration to meet network demands.
- D-Link DMS 1250-18P - switch - 16 ports - smart
- Switch - 16 ports - L2+ - smart
- Subtype
- 2.5 Gigabit Ethernet
- Ports
- 16 x 10/100/1000/2.5G (PoE+) + 2 x 10 Gigabit SFP+
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 370 W
- Performance
- Switching capacity: 120 Gbps , Packet forwarding rate: 89.29 Mpps
- Capacity
- MAC addresses per port: 64 , Static MAC entries: 256 , Packet buffer size: 16 Mbit , IGMP groups: 256 , MLD groups: 256 , Link aggregation groups: 8 , Link aggregation ports per channel: 8 , VLAN groups: 4094 , Queues per port: 8 , IPv4 routes (static): 128 , IPv6 routes (static): 64 , Port security entries: 64 , ARP entries: 64
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 12KB
- Routing Protocol
- Static IP routing, STP, MSTP, RSTP, IGMP, IGMPv2, IGMPv3, MLD, MLDv2
- Remote Management Protocol
- IPv6, IPv4, DHCP, Telnet, TFTP, SNMP, SNMP 2c, SNMP 3, CLI, BOOTP, ICMP, RMON, MIB
- 6KV Surge protection, QoS, port mirroring, IGMP snooping, MLD snooping, 3 fans, ACL support, Flooding Storm Control, Port Security, Voice VLAN, DSCP Marking, auto-uplink (auto MDI/MDI-X), store and forward, loopback detection, LLDP support, LLDP-MED, flow control, EEE, HOL Blocking Prevention, Multicast filtering function, PD-Alive, DDM, WRR, bandwidth control, VLAN support, NDP, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, DoS attack prevention, DHCP server, ARP inspection, IPMB, ARP support, AAA, 802.1x authentication, OTP, Cable Diagnostics Function, SNMP trap, TFTP client, Telnet server, firmware upgradable, SNTP support
- IEEE 802.3u, IEEE 802.3ab, IEEE 802.3bz, IEEE 802.3an, IEEE 802.3ae, IEEE 802.3z, IEEE 802.3az, IEEE 802.3ad (LACP), IEEE 802.1D, IEEE 802.1s, IEEE 802.1w, IEEE 802.3x, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x, IEEE 802.3af, IEEE 802.3bt
- Power
- AC 100-240 V (50/60 Hz)
- 44 cm x 25 cm x 4.4 cm
- 3.524 kg
- Localisation
- United Kingdom
- Enclosure Type
- Desktop
- Subtype
- Ports
- PoE+
- PoE Budget
- 370 W
- Performance
- Capacity
- 16K entries
- 12KB
- Routing Protocol
- Encryption Algorithm
- TLS 1.3, TTLS, PEAP, MD5
- Authentication Method
- RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
- RAM
- 512 MB
- Flash Memory
- 32 MB
- Status Indicators
- Power, link/activity/speed
- 16 x 10/100/1000/2.5G RJ-45 PoE+ - 90 W , 2 x 10GBase-X SFP+ uplink , 1 x console RJ-45
- Power Device
- Internal power supply
- Voltage Required
- CB, UL, BSMI, VCCI Class A, FCC Class A certified, RCM, IC, IEEE 61000-4-5
- Localisation
- United Kingdom
- 44 cm
- 25 cm
- 4.4 cm
- 3.524 kg
- -5 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
