Computers do not require Internet access all the time; neither do switches utilize all ports at all times. When a computer or network equipment is shutdown, switches often remain on and continue to consume considerable amount of power. With Green Ethernet technology, D-Link switches can automatically detect link status and reduce power usage of ports that are idle. Computers or any connecting parties set to standby mode (not power off), however, will not provide significant power savings.
The Green Ethernet switches have the ability to analyze the length of any Ethernet cable connected to them for adjustment of power usage accordingly. Shorter lengths require less power.
For a traditional switch, power consumption remains constant even when the ports are not in use. In a standard workday scenario where PCs are used for 10 hours a day and powered off 14 hours a day, and connected to the switch using 20 meter cables, D-Link's Green Ethernet can save up to 20% power used for each system.
Get the blazing speed of Gigabit Ethernet with the D-Link GigaExpress DGS-1016D, a 16-port 10/100/1000Mbps Gigabit Switch that delivers power, performance, and reliability in one cost-effective, space-saving design. Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality.
Power users in the office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files across the network instantly. The versatile and compact 1RU height design of the DGS-1016D enables the device to be rackmounted in a standard 19 inch rack, while conserving valuable rack space.
It features a non-blocking switching architecture that filters and forwards packets at full wire-speed for maximum throughput. An 8K MAC address table provides scalability for even the largest networks. Address learning and aging, 802.3x Flow Control for full-duplex mode, and back pressure flow control for half-duplex mode alleviates traffic congestion and ensures reliable data transmission.
Designed using industry standards, it is compatible with virtually all 10, 100, and 1000Mbps Ethernet devices and other vendor equipment. The D-Link DGS-1016D 10/100/1000 Mbps Gigabit Switch protects your existing network investments while providing you with a straightforward migration path to faster Gigabit speeds.
The auto features of this gigabit switch make installation plug and play and hassle-free. No configuring is required. Auto MDI/MDI-X crossover on all ports eliminate the need for crossover cables or uplink ports. Auto-negotiation on each port senses the link speed of a network device (10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance.
It also features diagnostic LEDs which display status and activity, allowing you to quickly detect and correct problems on the network. Every port also supports a cable diagnostic feature that helps to detect cable related problems.
* Product Highlights *
- Uses up to 40% less energy
- 16 Gigabit Ethernet ports
- 32Gbps switching capacity
- Desktop or rack-mountable design
- Non-blocking architecture
- D-Link DGS 1016D - switch - 16 ports - unmanaged - rack-mountable
- Switch - 16 ports - unmanaged
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000
- Performance
- Switching fabric bandwidth: 32 Gbps
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9600 bytes
- Flow control, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, QoS, Jumbo Frames support, Cable Diagnostics Function, D-Link Green Technology, fanless, Energy Efficient Ethernet
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 28 cm x 18 cm x 4.4 cm
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000
- Performance
- 8K entries
- 9600 bytes
- Status Indicators
- Port transmission speed, power, link/activity
- 16 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- FCC Class A certified, cUL, CB, ICES-003 Class A, RoHS, C-Tick Class A, VCCI Class A
- 28 cm
- 18 cm
- 4.4 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.73 |
Resources
The following resources are available for the D-Link 16-Port Green Ethernet Copper Gigabit Switch
Customer reviews
Write a review for the D-Link 16-Port Green Ethernet Copper Gigabit Switch here!
Google this product first
Reviewed by Anonymous Review Posted 11/02/2009
Works well for first few months them suffers from intermittent network lockups requiring hardware reset. Ports die one by one after that.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
