The D-Link DGS 1016S switch is designed to meet the needs of modern networking environments. Offering 16 gigabit ports with a 32 Gbps switching capacity, this device ensures that your network can handle substantial data traffic efficiently. Its energy-efficient design, featuring Energy-Efficient Ethernet (EEE) and a fanless operation, not only reduces operational costs but also contributes to a quieter office environment. With support for Quality of Service (QoS), jumbo frames, and a comprehensive packet buffer, the DGS 1016S prioritizes data delivery, making it a suitable solution for applications requiring high levels of data integrity and speed. Its durable construction and compliance with multiple standards, including Plug-and-Play and RoHS, make it a reliable and environmentally friendly choice for expanding your network.
Slim dimensions, hefty performance
The DGS-1016S 16-Port Gigabit Desktop Switch is ideal for home and small to medium-sized businesses (SMB) to add a quick and easy Gigabit upgrade to the network. Fully IEEE 802.3az-compliant with advanced energy-saving features, the DGS-1016S packs full functionality and Gigabit performance into a slim yet sturdy metal design. -
Good for the planet, good for your budget
The eco-friendly DGS-1016S is compliant with energy-efficient Ethernet (IEEE 802.3az) standards to save energy and reduce heat emissions without sacrificing performance and functionality. When low-traffic or idle interface ports are detected, the DGS-1016S automatically transitions them into a low-power state, substantially reducing overall device power consumption. Furthermore, the DGS-1016S can determine the approximate length of cables attached to each port to apply just enough power for data transmission on that link, saving even more power while lowering total cost of ownership (TCO). -
Fanless soundless performance
The DGS-1016S features a fanless design for silent operation, reduced energy consumption, and enhanced reliability by eliminating a common point of failure. -
Prioritize what's important with quality of service
Quality of Service (QoS) support also enhances your network's efficiency. QoS cleverly prioritizes network traffic so that time-sensitive data, such as VoIP or surveillance footage, are unaffected even during bursts of high-volume traffic. This allows for an all-round smoother, uninterrupted network experience.
 - D-Link DGS 1016S - switch - 16 ports - unmanaged
 - Switch - 16 ports - unmanaged
- Subtype
 - Gigabit Ethernet
- Ports
 - 16 x 10/100/1000
- Performance
 - Switching capacity: 32 Gbps , Packet forwarding rate: 1488000 packets per second
- Capacity
 - Queues: 8
- MAC Address Table Size
 - 8K entries
- Jumbo Frame Support
 - 9216 bytes
 - Flow control, auto-uplink (auto MDI/MDI-X), store and forward, QoS, fanless, 512KB packet buffer, EEE, cable length detection
 - IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Power
 - 1 A
 - 28 cm x 11 cm x 2.5 cm
 - 770 g
 - 2-year warranty
- Enclosure Type
 - Desktop
- Subtype
 - Gigabit Ethernet
- Ports
 - 16 x 10/100/1000
- Performance
- Capacity
 - Queues: 8
 - 8K entries
 - 9216 bytes
- Status Indicators
 - Port transmission speed, power, link/activity
 - 16 x 1000Base-T RJ-45
- Power Device
 - External power adapter
- Power Provided
 - DC 12 V
- Electric Current Required
 - 1 A
- Power Consumption Stand by
 - 3.37 Watt
- MTBF
 - 564,658 hours
 - Plug and Play, FCC Class A certified, ICES-003, RoHS, LVD
 - 28 cm
 - 11 cm
 - 2.5 cm
 - 770 g
 - Limited warranty - 2 years
 - 0 °C
 - 40 °C
 - 10 - 90% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
 - 5 - 95% (non-condensing)
