D-Link 16-Port 10/100/1000Mbps Unmanaged Gigabit Ethernet Switch
Quicklinx: J7LHWS00 Mfr#: DGS-1016S/B
£59.32 ex VAT
£71.18 inc VAT
The D-Link DGS 1016S switch is designed to meet the needs of modern networking environments. Offering 16 gigabit ports with a 32 Gbps switching capacity, this device ensures that your network can handle substantial data traffic efficiently. Its energy-efficient design, featuring Energy-Efficient Ethernet (EEE) and a fanless operation, not only reduces operational costs but also contributes to a quieter office environment. With support for Quality of Service (QoS), jumbo frames, and a comprehensive packet buffer, the DGS 1016S prioritizes data delivery, making it a suitable solution for applications requiring high levels of data integrity and speed. Its durable construction and compliance with multiple standards, including Plug-and-Play and RoHS, make it a reliable and environmentally friendly choice for expanding your network.
  • Slim dimensions, hefty performance
    The DGS-1016S 16-Port Gigabit Desktop Switch is ideal for home and small to medium-sized businesses (SMB) to add a quick and easy Gigabit upgrade to the network. Fully IEEE 802.3az-compliant with advanced energy-saving features, the DGS-1016S packs full functionality and Gigabit performance into a slim yet sturdy metal design.
  • Good for the planet, good for your budget
    The eco-friendly DGS-1016S is compliant with energy-efficient Ethernet (IEEE 802.3az) standards to save energy and reduce heat emissions without sacrificing performance and functionality. When low-traffic or idle interface ports are detected, the DGS-1016S automatically transitions them into a low-power state, substantially reducing overall device power consumption. Furthermore, the DGS-1016S can determine the approximate length of cables attached to each port to apply just enough power for data transmission on that link, saving even more power while lowering total cost of ownership (TCO).
  • Fanless soundless performance
    The DGS-1016S features a fanless design for silent operation, reduced energy consumption, and enhanced reliability by eliminating a common point of failure.
  • Prioritize what's important with quality of service
    Quality of Service (QoS) support also enhances your network's efficiency. QoS cleverly prioritizes network traffic so that time-sensitive data, such as VoIP or surveillance footage, are unaffected even during bursts of high-volume traffic. This allows for an all-round smoother, uninterrupted network experience.
D-Link DGS 1016S - switch - 16 ports - unmanaged
Switch - 16 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
Switching capacity: 32 Gbps , Packet forwarding rate: 1488000 packets per second
Queues: 8
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Flow control, auto-uplink (auto MDI/MDI-X), store and forward, QoS, fanless, 512KB packet buffer, EEE, cable length detection
IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
1 A
28 cm x 11 cm x 2.5 cm
770 g
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
Queues: 8
8K entries
Jumbo Frame Support
9216 bytes
Status Indicators
Port transmission speed, power, link/activity
16 x 1000Base-T RJ-45
External power adapter
Power Provided
DC 12 V
Electric Current Required
1 A
Power Consumption Stand by
3.37 Watt
MTBF
564,658 hours
Plug and Play, FCC Class A certified, ICES-003, RoHS, LVD
28 cm
11 cm
2.5 cm
770 g
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
Brand: D-Link
