D-Link's DGS-1100 Series provide an affordable solution for SOHOs and Small and Medium Businesses as well as enterprise deployment, such as in branch offices and meeting rooms that require simple network management. Most models comes in a compact desktop-sized metal case and features a wide selection of Gigabit port configurations with optional Gigabit fiber uplink ports. There are 4 switches in the series supporting Power-over-Ethernet with 2 of the switches in the offering high-power-budget PoE for businesses looking to power VoIP phones, wireless access points or network cameras.
Resilience and performance
The basic lineup of L2 features in the EasySmart series makes them very suitable for SMB with small IT teams, without sacrificing on performance and security. Network downtime is reduced drastically with loopback detection and broadcast storm control. Security and confidentiality of network traffic is guaranteed with VLANs. Ample bandwidth on the uplinks to the rest of the network can be achieved with link aggregation, and the cable diagnostics function provides an easy and convenient way to quickly detect and troubleshoot cabling problems. -
Versatile management
The EasySmart series can be easily configured through an intuitive, password-protected web-based interface. The web interface allows network administrators to remotely control and monitor the switch down to the port level.
- D-Link EasySmart Switch DGS-1100-16 - switch - 16 ports - Managed
- Switch - 16 ports - Managed
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000
- Performance
- Switching capacity: 32 Gbps , Forwarding performance (full duplex): 23.8 Mpps
- MAC Address Table Size
- 8K entries
- Remote Management Protocol
- HTTP
- Flow control, Layer 2 switching, DHCP support, trunking, VLAN support, IGMP snooping, port mirroring, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, QoS, bandwidth control
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
- Power
- AC 120/230 V (50/60 Hz)
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000
- Performance
- 8K entries
- HTTP
- RAM
- 2 MB
- Status Indicators
- Port transmission speed, power, link/activity
- 16 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- FCC Class A certified, cUL, VCCI Class A ITE
- 0 °C
- 40 °C
- 10 - 95%
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 95%
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.94 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.76 |
