This RPS is equipped with an integrated detection circuit that continuously monitors the switching device's internal power supply. In the event of a power interruption, the redundant power supply is immediately triggered so that the LAN switch and its connected devices can continue providing service. This results in a more reliable network infrastructure and protects the network from a single failure of a network device power supply. It is suitable for DGS-3427, DGS-3450, DGS-3300 Series, DXS-3300 Series, DGS-3600 Series, DGS-3048, DGS-3100-48.
- D-Link DPS-500 - power supply - 160 Watt
- Power supply
- 1.5 kg
- Input Voltage
- AC 115/230 V
- Output Voltage
- +5, +12 V
- Power Capacity
- 160 Watt
- 19.5 cm x 19.6 cm x 5 cm
- Designed For
- DGS 3100-48, 3324SR, 3324SRi; xStack DGS-3426, DGS-3427, DGS-3450, DGS-3612G, DGS-3627, DGS-3627G, DGS-3650, DXS-3326GSR, DXS-3350SR
- Power supply
- Input Voltage
- AC 115/230 V
- Input Voltage Range
- AC 90 - 264 V
- Frequency Required
- 47 - 63 Hz
- Output Voltage
- +5, +12 V
- Power Capacity
- 160 Watt
- FCC Class B certified, CSA, cUL, EN 60950, UL 60950
- 0 °C
- 50 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 80 °C
- 20 - 80%
- Humidity Range Storage
- 10 - 90%
- 19.5 cm
- 19.6 cm
- 5 cm
- 1.5 kg
- Designed For
- D-Link DGS 3100-48, 3324SR, 3324SRi , D-Link xStack DGS-3426, DGS-3427, DGS-3450, DGS-3612G, DGS-3627, DGS-3627G, DGS-3650, DXS-3326GSR, DXS-3350SR
