The D-Link DMS 1250-12TP switch is designed to meet the demands of modern businesses, offering a blend of performance, security, and flexibility. With robust security features, including advanced encryption and authentication methods, it ensures a secure network environment. The switch's high-capacity networking capabilities, supported by a 120 Gbps switching capacity and an 89.29 Mpps packet forwarding rate, make it suitable for handling large volumes of data traffic. Versatile connectivity options, including multi-gigabit PoE+ ports and 10GBase-T/SFP+ ports, provide the flexibility needed for network expansion and integration of high-speed devices. Additionally, the switch's enhanced power management features, including a generous 240 W PoE budget, facilitate the deployment of PoE devices, reducing installation costs and complexity. With comprehensive network management tools and support for advanced protocols, the D-Link DMS 1250-12TP is an ideal solution for businesses looking to optimize their network performance and security.
Robust security
With support for Extensible Authentication Protocol (EAP), RADIUS, TACACS+, and advanced encryption algorithms including MD5, PEAP, TLS 1.3, and TTLS, this switch ensures secure network access and data transmission. -
High-capacity networking
Equipped with a 120 Gbps switching capacity and a packet forwarding rate of 89.29 Mpps, the D-Link DMS 1250-12TP handles large data volumes efficiently, making it suitable for high-traffic networks. -
Featuring 8 ports of 10/100/1G/2.5G (PoE+), 2 ports of 10GBase-T, and 2 SFP+ ports for 10GBase-X connections, this switch offers flexible options for network expansion and integration of high-speed devices. -
Enhanced power management
With a total PoE budget of 240 W and support for PoE+, the switch provides power and connectivity to PoE devices such as IP cameras and VoIP phones, simplifying infrastructure and reducing installation costs. -
Comprehensive network management
Supporting a wide range of remote management protocols including SNMP, RMON, and Telnet, alongside advanced features like VLAN support and Quality of Service (QoS), this switch offers granular control over network traffic and resource allocation.
 - D-Link DMS 1250-12TP - switch - 8 ports - smart
 - Switch - 8 ports - L2+ - smart
- Subtype
 - 2.5 Gigabit Ethernet
- Ports
 - 8 x 10/100/1000/2.5G (PoE+) + 2 x 10 Gigabit Ethernet + 2 x 10 Gigabit SFP+
- Power Over Ethernet (PoE)
 - PoE+
- PoE Budget
 - 240 W
- Performance
 - Switching capacity: 120 Gbps , Packet forwarding rate: 89.29 Mpps
- Capacity
 - MAC addresses per port: 64 , Static MAC entries: 256 , Packet buffer size: 12 Mbit , IGMP groups: 256 , MLD groups: 256 , Link aggregation groups: 8 , Link aggregation ports per channel: 8 , VLAN groups: 4094 , Queues per port: 8 , IPv4 routes (static): 128 , IPv6 routes (static): 64 , Port security entries: 64 , ARP entries: 64
- MAC Address Table Size
 - 16K entries
- Jumbo Frame Support
 - 12KB
- Routing Protocol
 - Static IP routing, STP, MSTP, RSTP, IGMP, IGMPv2, IGMPv3, MLD, MLDv2
- Remote Management Protocol
 - IPv6, IPv4, DHCP, Telnet, TFTP, SNMP, SNMP 2c, SNMP 3, CLI, BOOTP, ICMP, RMON, MIB
 - 6KV Surge protection, DiffServ support, QoS, port mirroring, DHCP relay, IGMP snooping, MLD snooping, 2 fans, ACL support, Flooding Storm Control, Port Security, Voice VLAN, DSCP Marking, auto-uplink (auto MDI/MDI-X), store and forward, loopback detection, LLDP support, LLDP-MED, flow control, EEE, HOL Blocking Prevention, Multicast filtering function, PD-Alive, DDM, WRR, bandwidth control, VLAN support, NDP, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, DoS attack prevention, DHCP server, IPMB, ARP inspection, ARP support, AAA, 802.1x authentication, OTP, Cable Diagnostics Function, SNMP trap, TFTP client, Telnet server, firmware upgradable, SNTP support
 - IEEE 802.3u, IEEE 802.3ab, IEEE 802.3bz, IEEE 802.3an, IEEE 802.3ae, IEEE 802.3z, IEEE 802.3az, IEEE 802.3ad (LACP), IEEE 802.1D, IEEE 802.1s, IEEE 802.1w, IEEE 802.3x, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x, IEEE 802.3at, IEEE 802.3af
- Power
 - AC 100-240 V (50/60 Hz)
 - 44 cm x 21 cm x 4.4 cm
 - 3.24 kg
- Localisation
 - United Kingdom
 - Limited lifetime warranty
- Enclosure Type
 - Desktop
- Subtype
- Ports
 - PoE+
- PoE Budget
 - 240 W
- Performance
- Capacity
 - 16K entries
 - 12KB
- Routing Protocol
- Encryption Algorithm
 - TLS 1.3, TTLS, PEAP, MD5
- Authentication Method
 - RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
- RAM
 - 512 MB
- Flash Memory
 - 32 MB
- Status Indicators
 - Power, link/activity/speed, PoE max
 - 8 x 10/100/1G/2.5G (PoE+) RJ-45 30 W , 2 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x console RJ-45
- Power Device
 - Internal power supply
- Voltage Required
 - IEEE 61000-4-5, CB, UL, BSMI, VCCI Class A, FCC Class A certified, IC, RCM
- Localisation
 - United Kingdom
 - 44 cm
 - 21 cm
 - 4.4 cm
 - 3.24 kg
 - Limited warranty - lifetime
 - -5 °C
 - 50 °C
 - 0 - 95% (non-condensing)
- Min Storage Temperature
 - -20 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
