D-Link 10GBase-SR SFP+ Transceiver, 80/300m - tray of 10
Quicklinx: J7LWWS00 Mfr#: DEM-431XT/10
£560.74 ex VAT
£672.88 inc VAT
D-Link's 10 G SFP+ module series are hot-swappable SFP+ transceivers that plug into SFP+ slots on switches and support 10 G Ethernet. The D-Link 10GBase SFP+ module series transceivers offer customers a wide variety of 10 G Ethernet connectivity options for data centers, enterprise wiring closets, and service provider transport applications.
The transceivers use the Enhanced Small Formfactor Pluggable format (SFP+). The SFP+ form factor is smaller than other form factors such as Xenpak, X2, and 10 G XFP, ensuring lower costs, lower power disruption, and higher port density. They provide the necessary signal amplification for data to be transmitted to the network cable from the port, and vice versa, for the port to receive data from the network cable.
All D-Link transceivers are hot-pluggable. You can connect a transceiver while the system is powered on without causing any problems. This permits modules to be added or removed without interrupting the network. The transceivers all support 10 G Ethernet, which results in very fast data transmissions of up to 10 Gbit/s. This is 10 times faster than Gigabit Ethernet and enables the switch to handle faster and higher data transmissions, making it very suitable for business needs.
  • Enhanced small form-factor pluggable format
  • Hot pluggable
  • 10 G Ethernet speeds
  • Digital Diagnostics Monitoring (DDM)
    Several of the 10 G SFP+ modules feature DDM realtime monitoring of critical parameters, including transmitted and received power, temperature, and voltage. This allows for convenient monitoring of the module's fiber connection and early detection of problems.
D-Link DEM 431XT - SFP+ transceiver module - 10GbE
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10GbE
Max Transfer Distance
300 m
1.48 cm x 5.65 cm x 1.185 cm
18 g
Plug-in module
Wired
Cabling Type
10GBase-SR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
IEEE 802.3ae
1 x Ethernet 10GBase-SR
MTBF
3,960,000 hours
TUV, VCCI, FCC, RoHS, CDRH
1.48 cm
5.65 cm
1.185 cm
18 g
70 °C
5 - 85%
Brand: D-Link
Price Range Ex VAT: £500 - £750
