The D-Link DXS 3410-32XY switch is designed to meet the demands of modern network environments, offering a blend of performance, efficiency, and manageability. With its comprehensive set of features including high-speed 10 Gigabit Ethernet ports, advanced Layer 3 switching, and energy-saving technologies, this device is an ideal choice for businesses looking to upgrade their network infrastructure. The switch's stackable design and support for hot-plug power supplies ensure scalability and reliability, making it a valuable asset for growing enterprises. Additionally, its robust security features and easy management capabilities allow for a secure, easily monitored network. Whether you're looking to support high-volume data traffic, reduce operational costs, or expand your network, the D-Link DXS 3410-32XY offers a powerful solution that can adapt to your needs.
Advanced connectivity
With a variety of ports including 24 10 Gigabit Ethernet, 4 10 Gigabit SFP+, and 4 25 Gigabit SFP28, the D-Link DXS 3410-32XY ensures versatile connectivity options for a wide range of network needs. -
Robust performance
Boasting a switching capacity of 760 Gbps and a packet forwarding rate of 565.44 Mpps, this switch is engineered to handle substantial data traffic, providing efficient and reliable network performance. -
Enhanced manageability
Equipped with Layer 3 advanced switching capabilities and support for various remote management protocols including SNMP, CLI, and Telnet, this device offers comprehensive control and easy management of your network infrastructure. -
Energy-efficient design
Featuring D-Link Green technology and Energy-Efficient Ethernet (EEE), the DXS 3410-32XY is designed to optimize power usage, reducing operational costs and environmental impact. -
High reliability
With an MTBF of over 434,000 hours and support for hot-plug power supplies, this switch promises high reliability and uninterrupted service, ensuring your network remains operational at all times.
- D-Link DXS 3410-32XY - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 24 x 10 Gigabit Ethernet + 4 x 10 Gigabit SFP+ + 4 x 25 Gigabit SFP28
- Performance
- Switching capacity: 760 Gbps , Packet forwarding rate: 565.44 Mpps , Stacking bandwidth (full-duplex): 200 Gbps , Baud rate: 115200 bits/s
- Capacity
- Static MAC entries: 1000 , Buffer capacity (MB): 4 , Priority queues: 8 , Link aggregation groups: 32 , Link aggregation ports: 8 , IPv4 routes (static): 256 , IPv6 routes (static): 128 , MAC ACL entries (ingress): 1280 , MAC ACL entries (egress): 1024 , IPv4 ACL entries (ingress): 2560 , IPv4 ACL entries (egress): 1024 , IPv6 ACL entries (ingress): 640 , IPv6 ACL entries (egress): 512
- MAC Address Table Size
- 288K entries
- Jumbo Frame Support
- 10KB
- Routing Protocol
- Static IP routing, OSPF, RIP, RIPng, IGMP, IGMPv2, IGMPv3, MLD, MLDv2, VRRP, STP, PIM-SM, MSTP, RSTP
- Remote Management Protocol
- CLI, Telnet, SNMP, SNMP 1, SNMP 2c, SNMP 3, MIB, IPv6, IPv4, DHCP, ICMP, TFTP, RMON 1, RMON 2, RMON 3, RMON 9
- D-Link Green Technology, reset button, ZTP, security slot (Kensington security lock compatible), quiet mode (fan off), duplex chain topology support, duplex ring topology support, store and forward, EEE, full duplex mode, flow control, auto-uplink (auto MDI/MDI-X), auto-negotiation, QinQ VLAN, PFC, Link Aggregation, ERPS, loopback detection, flow mirroring, IGMP snooping, MLD snooping, QoS, port mirroring, DHCP relay, ACL support, Port Security, Voice VLAN, DSCP Marking, LLDP support, LLDP-MED, HOL Blocking Prevention, DDM, WRR, bandwidth control, VLAN support, NDP, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, DoS attack prevention, DHCP server, IPMB, ARP inspection, ARP support, 802.1x authentication, SNMP trap, TFTP client, Telnet server, SNTP support
- IEEE 802.3az, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3bz, IEEE 802.3an, IEEE 802.3x, IEEE 802.3z, IEEE 802.3ah, IEEE 802.3ae, IEEE 802.3by, IEEE 802.1Qbb, IEEE 802.1ag, ITU-T Y.1731, IEEE 802.3ad (LACP), IEEE 802.1D, IEEE 802.1s, IEEE 802.1w, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x
- Power
- AC 100-240 V (50/60 Hz) 2 A
- Power Redundancy
- 44.1 cm x 25 cm x 4.4 cm
- 3.73 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Ports
- Performance
- Capacity
- 288K entries
- 10KB
- Max Units In A Stack
- 9
- Routing Protocol
- Built-in Devices
- 3 x fans
- Status Indicators
- Fan failure, console, RPS (Redundant Power Supply), USB, link/activity, stack ID, power
- 24 x 100/1000/2.5G/5G/10GBase-T RJ-45 , 4 x 1/10GBase-X SFP+ , 4 x 10/25GBase-X SFP28 , 1 x USB 2.0 Type A , 1 x console RJ-45 , 1 x management (Gigabit LAN) RJ-45
- Power Device
- Internal power supply - hot-plug
- Power Redundancy
- Voltage Required
- Electric Current Required
- 2 A
- Power Consumption Stand by
- 41.8 Watt
- Included Accessories
- Cable retainer, 4 rubber feet
- Cables Included
- 1 x console cable
- Rack Mounting Kit
- Included
- MTBF
- 434,433.8793 hours
- FCC Part 15, CISPR 32 Class A, VCCI-A, BSMI, Laser Class 1, UKCA Class A, FCC Class A certified, ISED Class A, VCCI Class A, RCM Class A, BSMI Class A, UL 62368-1, CB IEC 60950 1, IEC 62368-1 CB Scheme, LVD 62368-1, IC, RCM, CB, cUL
- Localisation
- United Kingdom
- 44.1 cm
- 25 cm
- 4.4 cm
- 3.73 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 10 - 90% RH (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 95% RH (non-condensing)
