D-Link 10G Layer 3 Stackable Managed Switches
Quicklinx: J7K0WS00 Mfr#: DXS-3410-32XY/B
£2,559.80 ex VAT
£3,071.76 inc VAT
The D-Link DXS 3410-32XY switch is designed to meet the demands of modern network environments, offering a blend of performance, efficiency, and manageability. With its comprehensive set of features including high-speed 10 Gigabit Ethernet ports, advanced Layer 3 switching, and energy-saving technologies, this device is an ideal choice for businesses looking to upgrade their network infrastructure. The switch's stackable design and support for hot-plug power supplies ensure scalability and reliability, making it a valuable asset for growing enterprises. Additionally, its robust security features and easy management capabilities allow for a secure, easily monitored network. Whether you're looking to support high-volume data traffic, reduce operational costs, or expand your network, the D-Link DXS 3410-32XY offers a powerful solution that can adapt to your needs.
  • Advanced connectivity
    With a variety of ports including 24 10 Gigabit Ethernet, 4 10 Gigabit SFP+, and 4 25 Gigabit SFP28, the D-Link DXS 3410-32XY ensures versatile connectivity options for a wide range of network needs.
  • Robust performance
    Boasting a switching capacity of 760 Gbps and a packet forwarding rate of 565.44 Mpps, this switch is engineered to handle substantial data traffic, providing efficient and reliable network performance.
  • Enhanced manageability
    Equipped with Layer 3 advanced switching capabilities and support for various remote management protocols including SNMP, CLI, and Telnet, this device offers comprehensive control and easy management of your network infrastructure.
  • Energy-efficient design
    Featuring D-Link Green technology and Energy-Efficient Ethernet (EEE), the DXS 3410-32XY is designed to optimize power usage, reducing operational costs and environmental impact.
  • High reliability
    With an MTBF of over 434,000 hours and support for hot-plug power supplies, this switch promises high reliability and uninterrupted service, ensuring your network remains operational at all times.
D-Link DXS 3410-32XY - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 10 Gigabit Ethernet + 4 x 10 Gigabit SFP+ + 4 x 25 Gigabit SFP28
Performance
Switching capacity: 760 Gbps , Packet forwarding rate: 565.44 Mpps , Stacking bandwidth (full-duplex): 200 Gbps , Baud rate: 115200 bits/s
Static MAC entries: 1000 , Buffer capacity (MB): 4 , Priority queues: 8 , Link aggregation groups: 32 , Link aggregation ports: 8 , IPv4 routes (static): 256 , IPv6 routes (static): 128 , MAC ACL entries (ingress): 1280 , MAC ACL entries (egress): 1024 , IPv4 ACL entries (ingress): 2560 , IPv4 ACL entries (egress): 1024 , IPv6 ACL entries (ingress): 640 , IPv6 ACL entries (egress): 512
MAC Address Table Size
288K entries
Jumbo Frame Support
10KB
Routing Protocol
Static IP routing, OSPF, RIP, RIPng, IGMP, IGMPv2, IGMPv3, MLD, MLDv2, VRRP, STP, PIM-SM, MSTP, RSTP
Remote Management Protocol
CLI, Telnet, SNMP, SNMP 1, SNMP 2c, SNMP 3, MIB, IPv6, IPv4, DHCP, ICMP, TFTP, RMON 1, RMON 2, RMON 3, RMON 9
D-Link Green Technology, reset button, ZTP, security slot (Kensington security lock compatible), quiet mode (fan off), duplex chain topology support, duplex ring topology support, store and forward, EEE, full duplex mode, flow control, auto-uplink (auto MDI/MDI-X), auto-negotiation, QinQ VLAN, PFC, Link Aggregation, ERPS, loopback detection, flow mirroring, IGMP snooping, MLD snooping, QoS, port mirroring, DHCP relay, ACL support, Port Security, Voice VLAN, DSCP Marking, LLDP support, LLDP-MED, HOL Blocking Prevention, DDM, WRR, bandwidth control, VLAN support, NDP, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, DoS attack prevention, DHCP server, IPMB, ARP inspection, ARP support, 802.1x authentication, SNMP trap, TFTP client, Telnet server, SNTP support
IEEE 802.3az, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3bz, IEEE 802.3an, IEEE 802.3x, IEEE 802.3z, IEEE 802.3ah, IEEE 802.3ae, IEEE 802.3by, IEEE 802.1Qbb, IEEE 802.1ag, ITU-T Y.1731, IEEE 802.3ad (LACP), IEEE 802.1D, IEEE 802.1s, IEEE 802.1w, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x
AC 100-240 V (50/60 Hz) 2 A
Power Redundancy
44.1 cm x 25 cm x 4.4 cm
3.73 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
288K entries
Jumbo Frame Support
10KB
Max Units In A Stack
9
Routing Protocol
Built-in Devices
3 x fans
Status Indicators
Fan failure, console, RPS (Redundant Power Supply), USB, link/activity, stack ID, power
24 x 100/1000/2.5G/5G/10GBase-T RJ-45 , 4 x 1/10GBase-X SFP+ , 4 x 10/25GBase-X SFP28 , 1 x USB 2.0 Type A , 1 x console RJ-45 , 1 x management (Gigabit LAN) RJ-45
Power Redundancy
Electric Current Required
2 A
Power Consumption Stand by
41.8 Watt
Cable retainer, 4 rubber feet
1 x console cable
Rack Mounting Kit
Included
MTBF
434,433.8793 hours
FCC Part 15, CISPR 32 Class A, VCCI-A, BSMI, Laser Class 1, UKCA Class A, FCC Class A certified, ISED Class A, VCCI Class A, RCM Class A, BSMI Class A, UL 62368-1, CB IEC 60950 1, IEC 62368-1 CB Scheme, LVD 62368-1, IC, RCM, CB, cUL
United Kingdom
44.1 cm
25 cm
4.4 cm
3.73 kg
Limited warranty - lifetime
50 °C
10 - 90% RH (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% RH (non-condensing)
Brand: D-Link
Price Range Ex VAT: £1500+
