D-Link 10G Layer 3 Stackable Managed Switches
Quicklinx: J7K1WS00 Mfr#: DXS-3410-32SY/B
£1,598.20 ex VAT
£1,917.84 inc VAT
The D-Link DXS 3410-32SY switch is designed to meet the demands of modern businesses, offering a blend of performance, security, and manageability. This rack-mountable switch features 28 10 Gigabit SFP+ ports and 4 25 Gigabit SFP28 ports, providing the bandwidth and speed required for high-volume network environments. Security is a priority, with support for RADIUS, SSH, TACACS+, and advanced encryption, ensuring secure network access and data protection. Administrators can leverage a variety of management protocols, including CLI, DHCP, DNS, and SNMP, for comprehensive control over the network. With a switching capacity of 760 Gbps and a packet forwarding rate of 565.44 Mpps, the D-Link DXS 3410-32SY efficiently handles large amounts of data, making it a suitable solution for enterprises with high traffic demands. Additionally, the switch incorporates D-Link Green technology, featuring smart fans that adjust to reduce power consumption, thereby lowering operational costs without compromising performance.
  • Advanced connectivity
    Equipped with 28 10 Gigabit SFP+ ports and 4 25 Gigabit SFP28 ports, this switch offers high-speed connectivity and enhanced network capacity, supporting demanding business applications.
  • Robust security features
    Features comprehensive security protocols including RADIUS, Secure Shell (SSH), TACACS+, and advanced encryption algorithms, ensuring secure network access and data transmission.
  • Efficient network management
    Manageable via CLI, DHCP, DNS, HTTPS, and SNMP among others, this switch provides flexible and powerful tools for network administration, simplifying the management of large-scale networks.
  • High performance
    With a switching capacity of 760 Gbps and a packet forwarding rate of 565.44 Mpps, this switch is designed to handle high volumes of traffic, ensuring efficient data flow across the network.
  • Energy-efficient design
    Incorporates D-Link Green technology with 3 smart fans, optimizing energy use and reducing operational costs, while maintaining performance and reliability.
D-Link DXS 3410-32SY - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
28 x 10 Gigabit SFP+ + 4 x 25 Gigabit SFP28
Performance
Switching capacity: 760 Gbps , Stacking bandwidth (full-duplex): 200 Gbps , Packet forwarding rate: 565.44 Mpps , Baud rate: 115200 bits/s
Static MAC entries: 1000 , Buffer capacity (MB): 4 , Priority queues: 8 , Link aggregation groups: 32 , Link aggregation ports: 8 , IPv4 routes (static): 256 , IPv6 routes (static): 128 , MAC ACL entries (ingress): 1280 , MAC ACL entries (egress): 1024 , IPv4 ACL entries (ingress): 2560 , IPv4 ACL entries (egress): 1024 , IPv6 ACL entries (ingress): 640 , IPv6 ACL entries (egress): 512 , Units per virtual stack: 32 , Port mirroring groups: 4 , IGMP groups: 1024 , MLD groups: 1024 , VLAN groups: 4000 , VLAN IDs: 4094 , Port security entries: 12000 , Maximum ARP Spoofing entries: 128 , IPv4 routes (ARP entries): 16128 , Static ARP entries: 512 , IPv6 ND entries: 7680 , Static ND entries: 256 , IP interfaces: 256 , Routing entries: 12000 , IPv4 forwarding entries (Layer 3): 16000 , IPv6 forwarding entries (Layer 3): 8000
MAC Address Table Size
32K entries
Jumbo Frame Support
10KB
Routing Protocol
Static IP routing, RIP, RIPng, OSPFv2, OSPFv3, STP, RSTP, MLD, MSTP, IGMP, IGMPv2, IGMPv3, MLDv2, NTPv3, NTPv4, VRRPv2, VRRPv3, ECMP, policy-based routing (PBR), RIP-2, PIM-SM
Remote Management Protocol
DHCP, CLI, TCP/IP, UDP, HTTPS, Telnet, TFTP, DNS, SNMP 1, SNMP 2c, SNMP 3, RMON 1, RMON 2, RMON 3, RMON 9, SMTP, MIB, IPv6, IPv4, ICMP
D-Link Green Technology, reset button, ZTP, security slot (Kensington security lock compatible), quiet mode (fan off), duplex chain topology support, duplex ring topology support, store and forward, EEE, full duplex mode, flow control, auto-uplink (auto MDI/MDI-X), auto-negotiation, High Availability, ERPS, loopback detection, PFC, Broadcast Storm Control, ACL support, IPMB, DHCP snooping, QoS, CoS, IPTV support, 802.1x authentication, WAC, MAC-based Access Control (MAC), VLAN support, HoL Blocking Prevention, Root Guard, Loop Guard, port mirroring, flow mirroring, VLAN mirroring, RSPAN, ERPS v2, iSCSI awareness, MLAG, IGMP snooping, fast leave, MLD snooping, PIM-SM snooping, GVRP, VLAN Double Tagging (Q-in-Q), port-based VLAN, Voice VLAN, Asymmetric VLAN, Private VLAN, VLAN trunking, Super VLAN, SP, WRR, WDRR, congestion control, WRED, DSCP support, trTCM, SRTCM, CIR, PIR, Multicast Storm Control, Unicast Storm Control, DHCP server, IP source guard, DAI, DHCPv6 guard, DAD, ARP spoofing, BPDU protection, DoS attack prevention, Guest VLAN, AAA, DULD, Dying Gasp support, DDM, SNMP trap, sFlow, LLDP-MED, DHCP client, D-Link DDP, SNTP server, Microsoft NLB, Link Aggregation, Port Security, DHCP relay, DSCP Marking, LLDP support, HOL Blocking Prevention, bandwidth control, NDP, ARP inspection, ARP support, TFTP client, Telnet server, SNTP support
IEEE 802.3az, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3bz, IEEE 802.3an, IEEE 802.3x, IEEE 802.3z, IEEE 802.3ah, IEEE 802.3ae, IEEE 802.3by, IEEE 802.1w, IEEE 802.1D, IEEE 802.1s, IEEE 802.1Q, IEEE 802.1ag, ITU-T Y.1731, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.1v, IEEE 802.1p, IEEE 802.1Qbb
AC 100-240 V (50/60 Hz) 2 A
Power Redundancy
44.1 cm x 25 cm x 4.4 cm
3.8 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
32K entries
Jumbo Frame Support
10KB
Max Units In A Stack
9
Routing Protocol
Encryption Algorithm
SSL, TLS 1.0, TLS 1.1, TLS 1.2
Authentication Method
Secure Shell (SSH), Secure Shell v.2 (SSH2), RADIUS, TACACS+
Built-in Devices
3 x smart fans
Status Indicators
Fan failure, console, RPS (Redundant Power Supply), USB, link/activity, stack ID, power
28 x 10GBase-X SFP+ , 4 x 10/25GBase-X SFP28 stacking , 1 x USB 2.0 Type A , 1 x console RJ-45 , 1 x management (Gigabit LAN) RJ-45
Power Redundancy
Electric Current Required
2 A
Power Consumption Stand by
29.3 Watt
Cable retainer, 4 rubber feet
1 x console cable
Rack Mounting Kit
Included
MTBF
437,675.04 hours
FCC Part 15, CISPR 32 Class A, VCCI-A, BSMI, Laser Class 1, UKCA Class A, FCC Class A certified, ISED Class A, VCCI Class A, RCM Class A, BSMI Class A, UL 62368-1, CB IEC 60950 1, IEC 62368-1 CB Scheme, LVD 62368-1, IC, RCM, CB, cUL
United Kingdom
44.1 cm
25 cm
4.4 cm
3.8 kg
Limited warranty - lifetime
50 °C
10 - 90% RH
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% RH
Brand: D-Link
Price Range Ex VAT: £1500+
