D-Link 10-Port PoE+ Gigabit Smart Managed Switch
Quicklinx: J7KHWS00 Mfr#: DGS-1100-10MPV2/B
£109.96 ex VAT
£131.95 inc VAT
The D-Link DGS 1100-10MPV2 switch is designed to meet the demands of modern networks, offering robust performance and efficient management capabilities. With a 20 Gbps switching capacity and 14.88 Mpps forwarding performance, it ensures high-speed data processing and efficient traffic handling, making it ideal for businesses requiring reliable network performance. The switch features 8 PoE ports and 2 Gigabit SFP ports, providing flexible connectivity options for various devices while supporting power and data transmission over a single network cable. It is built to withstand a wide range of environmental conditions, ensuring reliable operation in diverse settings. Additionally, the switch incorporates D-Link Green technology, optimizing power usage and reducing energy consumption for eco-friendly operation. With features like Quality of Service (QoS), VLAN support, and port mirroring, it offers comprehensive tools for optimizing traffic flow and enhancing network security. The D-Link DGS 1100-10MPV2 is a smart choice for businesses looking to upgrade their network infrastructure with a switch that combines performance, flexibility, and sustainability.
  • Smart web UI
    The DGS-1100's web user interface is an easy way to manage Layer 2 features, such as VLANs, Spanning Tree Protocol (STP), link aggregation (static). With powerful security features like IGMP snooping, Static MAC, and Storm Control, the DGS-1100 Smart family is a versatile solution for environments that require easy to deploy and easy to configure solutions without added complexities.
  • Easy to deploy and manage
    D-Link's free Network Assistant (DNA) displays all connected devices and speeds up the first time configuration. The free D-View 7 Network Management System comes with a license for 25 nodes and 2 probes and full access to the management tools.
  • PoE and PoE+
    The DGS-1100 Smart Series includes a range of high power budget PoE-enabled switches for businesses looking to power larger deployments of VoIP phones, wireless access points or network cameras.
  • Easy troubleshooting
    The DGS-1100 Series features Loopback Detection and Cable Diagnostics to help network administrators find and solve network problems quickly and easily. Loopback Detection is used to detect loops created by a specific port and automatically shut down the affected port. The Cable Diagnostics feature is designed for network administrators to quickly examine the quality of the copper cables, recognize the cable type, and detect cable errors.
D-Link DGS 1100-10MPV2 - switch - 10 ports - smart - rack-mountable
Switch - 10 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE) + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
130 W
Performance
Switching capacity: 20 Gbps , Forwarding performance: 14.88 Mpps
VLAN groups: 128 , VLAN IDs: 4094 , IGMP groups: 128 , QoS priority queues per port: 8 , Buffer capacity (MB): 4.1
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, RSTP, STP
Remote Management Protocol
SNMP 2, HTTP, ICMP, DHCP, MIB
Flow control, auto-negotiation, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, QoS, reset button, Cable Diagnostics Function, D-Link Green Technology, LLDP support, DHCP client, Voice VLAN, storm protection, EEE, WRR, HOL Blocking Prevention, loopback detection, port-based VLAN, Asymmetric VLAN, security slot (Kensington security lock compatible), mode button, Smart Fan, Static MAC, Auto Surveillance VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3at, IEEE 802.3az, IEEE 802.3bt
AC 100-240 V (50/60 Hz)
28 cm x 18 cm x 4.4 cm
1.5 kg
United Kingdom
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
130 W
Performance
8K entries
Jumbo Frame Support
10KB
Routing Protocol
Encryption Algorithm
SSL
Flash Memory
16 MB
Status Indicators
Power, PoE, link/activity/speed
8 x 1000Base-T RJ-45 PoE - 30 W , 2 x 1000Base-X SFP
Internal power supply
11.7 Watt
Power Consumption Stand by
5.6 Watt
11" rack mounting kit
Rack Mounting Kit
Included
MTBF
406,887 hours
FCC Class A certified, UL, C-Tick, BSMI, cUL, CB, LVD, VCCI Class A, RoHS 10
United Kingdom
Software Included
D-Link Network Assistant
28 cm
18 cm
4.4 cm
1.5 kg
Limited warranty - lifetime
-10 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: D-Link
