The D-Link DMS 1250-10S switch is engineered to meet the demands of modern networks, offering robust security, high performance, and advanced networking capabilities. With a switching capacity of 80 Gbps and support for up to 4094 VLAN groups, it is designed to facilitate efficient data flow and secure connectivity across the network. The switch's comprehensive security features, including support for various authentication methods and encryption algorithms, ensure a protected network environment. Additionally, its fanless design and energy-efficient operation make it an ideal choice for businesses looking to minimize noise and reduce operational costs. Whether for small businesses or large enterprises, the D-Link DMS 1250-10S provides a reliable, scalable, and secure networking solution.
Robust security
With support for Extensible Authentication Protocol (EAP), RADIUS, TACACS+, and encryption algorithms including MD5, PEAP, TLS 1.3, and TTLS, this switch ensures secure network access and data transmission. -
High performance
Equipped with a switching capacity of 80 Gbps and a packet forwarding rate of 59.53 Mpps, the D-Link DMS 1250-10S delivers efficient and reliable high-speed data processing. -
Advanced networking
Features such as Layer 2+ switching, VLAN support, Quality of Service (QoS), and support for multiple routing protocols including IGMP, MLD, and static IP routing, provide flexible and comprehensive network management options. -
Enhanced connectivity
This switch offers a variety of ports including 8 2.5GBase-T and 2 10GBase-X SFP+ ports, alongside a console port for versatile connectivity and network configuration options. -
Durable and reliable
Designed for longevity with 6 kV surge protection and a fanless design, ensuring operation in a wide range of temperatures from -5°C to 50°C without compromising performance.
 - D-Link DMS 1250-10S - switch - 8 ports - smart
 - Switch - 8 ports - L2+ - smart
- Subtype
 - 2.5 Gigabit Ethernet
- Ports
 - 8 x 2.5GBase-T + 2 x 10 Gigabit SFP+
- Performance
 - Switching capacity: 80 Gbps , Packet forwarding rate: 59.53 Mpps
- Capacity
 - MAC addresses per port: 64 , Static MAC entries: 256 , Packet buffer size: 12 Mbit , IGMP groups: 256 , MLD groups: 256 , Link aggregation groups: 8 , Link aggregation ports per channel: 8 , VLAN groups: 4094 , Queues per port: 8 , IPv4 routes (static): 128 , IPv6 routes (static): 64 , Port security entries: 64 , ARP entries: 64
- MAC Address Table Size
 - 16K entries
- Jumbo Frame Support
 - 12KB
- Routing Protocol
 - Static IP routing, STP, MSTP, RSTP, IGMP, IGMPv2, IGMPv3, MLD, MLDv2
- Remote Management Protocol
 - IPv6, IPv4, DHCP, Telnet, TFTP, SNMP, SNMP 2c, SNMP 3, CLI, BOOTP, ICMP, RMON, MIB
 - 6KV Surge protection, DiffServ support, QoS, port mirroring, DHCP relay, IGMP snooping, MLD snooping, fanless, ACL support, Flooding Storm Control, Port Security, Voice VLAN, DSCP Marking, auto-uplink (auto MDI/MDI-X), store and forward, loopback detection, LLDP support, LLDP-MED, flow control, EEE, HOL Blocking Prevention, Multicast filtering function, PD-Alive, DDM, WRR, bandwidth control, VLAN support, NDP, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, DoS attack prevention, DHCP server, IPMB, ARP inspection, ARP support, AAA, 802.1x authentication, OTP, Cable Diagnostics Function, SNMP trap, TFTP client, Telnet server, firmware upgradable, SNTP support
 - IEEE 802.3u, IEEE 802.3ab, IEEE 802.3bz, IEEE 802.3an, IEEE 802.3ae, IEEE 802.3z, IEEE 802.3az, IEEE 802.3ad (LACP), IEEE 802.1D, IEEE 802.1s, IEEE 802.1w, IEEE 802.3x, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x
- Power
 - AC 100-240 V (50/60 Hz)
 - 33 cm x 20 cm x 4.4 cm
 - 1.877 kg
- Localisation
 - United Kingdom
 - Limited lifetime warranty
- Enclosure Type
 - Desktop
- Subtype
- Ports
- Performance
- Capacity
 - 16K entries
 - 12KB
- Routing Protocol
- Encryption Algorithm
 - TLS 1.3, TTLS, PEAP, MD5
- Authentication Method
 - RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
- RAM
 - 512 MB
- Flash Memory
 - 32 MB
- Status Indicators
 - Power, link/activity/speed
 - 8 x 2.5GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x console RJ-45
- Power Device
 - Internal power supply
- Voltage Required
 - IEEE 61000-4-5, CB, UL, BSMI, VCCI Class A, FCC Class A certified, IC, RCM
- Localisation
 - United Kingdom
 - 33 cm
 - 20 cm
 - 4.4 cm
 - 1.877 kg
 - Limited warranty - lifetime
 - -5 °C
 - 50 °C
 - 0 - 95% RH
- Min Storage Temperature
 - -20 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
 - 0 - 95% RH
