D-Link 10-Port Multi-Gigabit Smart Managed PoE+ Switch 8 multi-Gigabit 2.5G PoE and 2 10G SFP+ ports
Quicklinx: J7L4WS00 Mfr#: DMS-1250-10SPL/B
£272.58 ex VAT
£327.09 inc VAT
The D-Link DMS 1250-10SPL switch is designed to meet the demands of modern businesses, offering a blend of performance, security, and flexibility. With a robust 80 Gbps switching capacity and a packet forwarding rate of 59.53 Mpps, this device ensures high-speed data transmission and efficient handling of network traffic. Security is a priority, with features like Extensible Authentication Protocol (EAP), RADIUS, TACACS+, and advanced encryption algorithms ensuring a secure network environment. The switch also offers versatile connectivity options, including PoE++ and SFP+ ports, to accommodate a variety of devices and applications. Its fanless design allows for silent operation, making it suitable for any workspace. With support for advanced network management features such as Quality of Service (QoS) and VLANs, the D-Link DMS 1250-10SPL is an ideal solution for businesses looking to enhance their network infrastructure.
  • Robust security
    With advanced security features like Extensible Authentication Protocol (EAP), RADIUS, TACACS+, and encryption algorithms including MD5, PEAP, TLS 1.3, and TTLS, this switch ensures secure network environments.
  • High-capacity networking
    Equipped with a 80 Gbps switching capacity and a packet forwarding rate of 59.53 Mpps, the D-Link DMS 1250-10SPL efficiently manages large volumes of data, making it ideal for growing businesses.
  • Versatile connectivity
    This switch offers a range of port types including 10/100/1G/2.5G (PoE+), 10/100/1000/2.5G (PoE++), and 10GBase-X SFP+ ports, providing flexible connection options for various network needs.
  • Enhanced power delivery
    With PoE++ support on two ports delivering up to 60 W and a total PoE budget of 120 W, this device can power high-demand network devices such as wireless access points and surveillance cameras.
  • Efficient network management
    Smart features like Quality of Service (QoS), VLAN support, and advanced Layer 2+ switching make network management simpler and more efficient, optimizing the flow of traffic and improving network segmentation.
D-Link DMS 1250-10SPL - switch - 8 ports - smart
Switch - 8 ports - L2+ - smart
Subtype
2.5 Gigabit Ethernet
Ports
2 x 10/100/1000/2.5G (PoE++) + 6 x 10/100/1000/2.5G (PoE+) + 2 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE++
PoE Budget
120 W
Performance
Switching capacity: 80 Gbps , Packet forwarding rate: 59.53 Mpps
MAC addresses per port: 64 , Static MAC entries: 256 , Packet buffer size: 12 Mbit , IGMP groups: 256 , MLD groups: 256 , Link aggregation groups: 8 , Link aggregation ports per channel: 8 , VLAN groups: 4094 , Queues per port: 8 , IPv4 routes (static): 128 , IPv6 routes (static): 64 , Port security entries: 64 , ARP entries: 64
MAC Address Table Size
16K entries
Jumbo Frame Support
12KB
Routing Protocol
Static IP routing, STP, MSTP, RSTP, IGMP, IGMPv2, IGMPv3, MLD, MLDv2
Remote Management Protocol
IPv6, IPv4, DHCP, Telnet, TFTP, SNMP, SNMP 2c, SNMP 3, CLI, BOOTP, ICMP, RMON, MIB
6KV Surge protection, DiffServ support, QoS, port mirroring, DHCP relay, IGMP snooping, MLD snooping, fanless, ACL support, Flooding Storm Control, Port Security, Voice VLAN, DSCP Marking, auto-uplink (auto MDI/MDI-X), store and forward, loopback detection, LLDP support, LLDP-MED, flow control, EEE, HOL Blocking Prevention, Multicast filtering function, PD-Alive, DDM, WRR, bandwidth control, VLAN support, NDP, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, DoS attack prevention, DHCP server, IPMB, ARP inspection, ARP support, AAA, 802.1x authentication, OTP, Cable Diagnostics Function, SNMP trap, TFTP client, Telnet server, firmware upgradable, SNTP support
IEEE 802.3u, IEEE 802.3ab, IEEE 802.3bz, IEEE 802.3an, IEEE 802.3ae, IEEE 802.3z, IEEE 802.3az, IEEE 802.3ad (LACP), IEEE 802.1D, IEEE 802.1s, IEEE 802.1w, IEEE 802.3x, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x, IEEE 802.3at, IEEE 802.3af, IEEE 802.3bt
21 cm x 21 cm x 4.4 cm
1.34 kg
United Kingdom
Enclosure Type
Desktop
Subtype
Ports
PoE++
PoE Budget
120 W
Performance
16K entries
Jumbo Frame Support
12KB
Routing Protocol
Encryption Algorithm
TLS 1.3, TTLS, PEAP, MD5
Authentication Method
RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
RAM
512 MB
Flash Memory
32 MB
Status Indicators
Power, link/activity/speed, PoE max
6 x 10/100/1G/2.5G (PoE+) RJ-45 30 W , 2 x 10/100/1000/2.5G (PoE++) RJ-45 60 W , 2 x 10GBase-X SFP+
External power adapter
Power Provided
DC 54 V - 2.78 A
IEEE 61000-4-5, CB, UL, BSMI, VCCI Class A, FCC Class A certified, IC, RCM
United Kingdom
21 cm
21 cm
4.4 cm
1.34 kg
Limited warranty - lifetime
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: D-Link
