D-Link 10-Port Multi-Gigabit Smart Managed PoE+ Switch 8 multi-Gigabit 2.5G PoE and 2 10G SFP+ ports
Quicklinx: J7KYWS00 Mfr#: DMS-1250-10SP/B
£327.20 ex VAT
£392.64 inc VAT
The D-Link DMS 1250-10SP switch is designed to meet the demands of modern network environments, offering robust performance, advanced security, and comprehensive networking capabilities. With a switching capacity of 80 Gbps and a packet forwarding rate of 59.53 Mpps, it ensures efficient data flow and high-speed connectivity. The switch's 240 W PoE budget and support for PoE+ enable the powering of multiple devices, simplifying the network infrastructure. Security is a priority, with features like 802.1x authentication, Access Control List (ACL) support, and DoS attack prevention ensuring a secure network infrastructure. Additionally, the switch supports a wide range of networking standards and features, including Quality of Service (QoS), VLAN support, and link aggregation, enhancing network management and reliability. With flexible port options, including 8 x 10/100/1G/2.5G (PoE+) and 2 x 10GBase-X SFP+ ports, the D-Link DMS 1250-10SP is a versatile solution that can accommodate various network needs and future-proof your investment.
  • Robust performance
    Equipped with a switching capacity of 80 Gbps and a packet forwarding rate of 59.53 Mpps, this switch ensures efficient data flow and high-speed connectivity for demanding network environments.
  • Comprehensive security
    Features such as 802.1x authentication, Access Control List (ACL) support, and DoS attack prevention provide a secure network infrastructure by mitigating threats and unauthorized access.
  • Advanced networking capabilities
    Supports a wide range of networking standards including IEEE 802.1Q, IEEE 802.1p, and IEEE 802.3at, alongside advanced features like Quality of Service (QoS), VLAN support, and link aggregation to enhance network management and reliability.
  • High power budget
    With a PoE budget of 240 W and support for PoE+, this switch can power multiple devices such as IP cameras, VoIP phones, and wireless access points, simplifying the network infrastructure.
  • Flexible connectivity
    Offers a variety of ports including 8 x 10/100/1G/2.5G (PoE+) and 2 x 10GBase-X SFP+ ports, providing versatile connection options for different network needs and future-proofing the investment.
D-Link DMS 1250-10SP - switch - 8 ports - smart
Switch - 8 ports - L2+ - smart
Subtype
2.5 Gigabit Ethernet
Ports
8 x 10/100/1000/2.5G (PoE+) + 2 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
240 W
Performance
Switching capacity: 80 Gbps , Packet forwarding rate: 59.53 Mpps
MAC addresses per port: 64 , Static MAC entries: 256 , Packet buffer size: 12 Mbit , IGMP groups: 256 , MLD groups: 256 , Link aggregation groups: 8 , Link aggregation ports per channel: 8 , VLAN groups: 4094 , Queues per port: 8 , IPv4 routes (static): 128 , IPv6 routes (static): 64 , Port security entries: 64 , ARP entries: 64
MAC Address Table Size
16K entries
Jumbo Frame Support
12KB
Routing Protocol
Static IP routing, STP, MSTP, RSTP, IGMP, IGMPv2, IGMPv3, MLD, MLDv2
Remote Management Protocol
IPv6, IPv4, DHCP, Telnet, TFTP, SNMP, SNMP 2c, SNMP 3, CLI, BOOTP, ICMP, RMON, MIB
6KV Surge protection, DiffServ support, QoS, port mirroring, DHCP relay, IGMP snooping, MLD snooping, 2 fans, ACL support, Flooding Storm Control, Port Security, Voice VLAN, DSCP Marking, auto-uplink (auto MDI/MDI-X), store and forward, loopback detection, LLDP support, LLDP-MED, flow control, EEE, HOL Blocking Prevention, Multicast filtering function, PD-Alive, DDM, WRR, bandwidth control, VLAN support, NDP, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, DoS attack prevention, DHCP server, IPMB, ARP inspection, ARP support, AAA, 802.1x authentication, OTP, Cable Diagnostics Function, SNMP trap, TFTP client, Telnet server, firmware upgradable, SNTP support
IEEE 802.3u, IEEE 802.3ab, IEEE 802.3bz, IEEE 802.3an, IEEE 802.3ae, IEEE 802.3z, IEEE 802.3az, IEEE 802.3ad (LACP), IEEE 802.1D, IEEE 802.1s, IEEE 802.1w, IEEE 802.3x, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x, IEEE 802.3at, IEEE 802.3af
AC 100-240 V (50/60 Hz)
33 cm x 20 cm x 4.4 cm
2.377 kg
United Kingdom
Enclosure Type
Desktop
Subtype
Ports
PoE+
PoE Budget
240 W
Performance
16K entries
Jumbo Frame Support
12KB
Routing Protocol
Encryption Algorithm
TLS 1.3, TTLS, PEAP, MD5
Authentication Method
RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
RAM
512 MB
Flash Memory
32 MB
Status Indicators
Power, link/activity/speed, PoE max
8 x 10/100/1G/2.5G (PoE+) RJ-45 30 W , 2 x 10GBase-X SFP+ , 1 x console RJ-45
Internal power supply
IEEE 61000-4-5, CB, UL, BSMI, VCCI Class A, FCC Class A certified, IC, RCM
United Kingdom
33 cm
20 cm
4.4 cm
2.377 kg
Limited warranty - lifetime
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: D-Link
