D-Link 10-Port Gigabit Stackable Smart Managed Switch with 2 x 10G SFP+ Ports
Quicklinx: J7KNWS00 Mfr#: DGS-1530-10/B
Type: Gigabit Ethernet
Ports: 10
Managed: Yes
£216.80 ex VAT
£260.16 inc VAT
The D-Link DGS 1530-10 is a robust switch designed for efficient networking in various environments. With a capacity for 255 IPv4 routes and 4094 VLAN groups, it supports extensive routing and network segmentation. Its stackable design accommodates up to 9 units, allowing for increased flexibility in expansion and management. The switch features a variety of ports, including 8 10/100/1000 Base-T and 2 10 Gigabit SFP+ ports, ensuring connectivity for diverse devices. With a compact form factor, it can be easily rack-mounted or used in desktop setups, making it adaptable to different configurations and spaces. The DGS 1530-10 incorporates features like D-Link Green technology for energy efficiency and is equipped with a fanless design that helps reduce noise in sensitive environments. Its support for advanced protocols such as RADIUS for authentication, VLAN support for network segmentation, and Quality of Service (QoS) ensures appropriate bandwidth allocation for various applications while maintaining network performance. Additionally, its environmental parameters allow for versatile operation in conditions, with temperature ranges from -5°C to 50°C and a humidity range of 0 - 95%, non-condensing.
  • Efficient Networking Capacity
    This switch supports 255 IPv4 routes and 4094 VLAN groups, providing extensive routing and network segmentation capabilities for complex networking requirements.
  • Versatile Port Selection
    Equipped with 8 10/100/1000 Base-T ports and 2 10 Gigabit SFP+ ports, the switch ensures flexibility and compatibility with various networking devices.
  • Advanced Security Features
    Incorporating RADIUS, Access Control Lists, and Denial of Service protection, this switch ensures a secure networking environment, safeguarding against potential threats.
  • Environmental Resilience
    With a temperature range from -5°C to 50°C and humidity resilience of 0 - 95%, this switch operates smoothly in varied environmental conditions, making it versatile for deployment.
  • User-friendly Management Options
    Supporting remote management protocols such as SNMP and Telnet, it enables easy monitoring and control of the network, enhancing operational efficiency.
D-Link DGS 1530-10 - switch - 10 ports - smart - rack-mountable
Switch - 10 ports - smart - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x 10 Gigabit SFP+
Performance
Switching capacity: 56 Gbps , Forwarding performance: 41.67 Mpps , Stacking bandwidth: 40 Gbps
IPv4 routes (static): 32 , IPv6 routes (static): 64 , VLAN groups: 4094 , IPv4 interfaces: 64 , IPv6 interfaces: 64 , Queues per port: 8 , Static MAC entries: 1024 , Units per virtual stack: 32 , Buffer capacity (MB): 1.5 , MLD groups: 1024 , Static ARP entries: 255
MAC Address Table Size
16K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
Static IP routing, IGMP, IGMPv2, IGMPv3, MLD, MLDv2, STP, RSTP, MSTP, L2PT
Remote Management Protocol
RMON 1, RMON 2, SNMP 1, SNMP 2c, SNMP 3, HTTP, Telnet, TFTP
6KV Surge protection, fanless, auto-negotiation, flow control, half/full duplex mode, auto-uplink (auto MDI/MDI-X), store and forward, ACL support, IPMB, ERPS, High Availability, RTC, Dying Gasp, Safeguard Engine, BPDU protection, ARP spoofing, DoS, Guest VLAN, LLDP support, LLDP-MED, QoS, D-Link SIM, HOL Blocking Prevention, Link Aggregation, AAA, sFlow, ZTP, D-Link DDP, loopback detection, D-Link Green Technology
IEEE 802.1ag, IEEE 802.1x, IEEE 802.3, IEEE 802.3ab, IEEE 802.3ae, IEEE 802.3u, IEEE 802.3x, IEEE 802.3ah, IEEE 802.1D, IEEE 802.1s, IEEE 802.1w, IEEE 802.1v, IEEE 802.1Q, IEEE 802.3ad (LACP), IEEE 802.3az
AC 100-240 V (50/60 Hz)
Power Redundancy
Optional
28 cm x 18 cm x 4.4 cm
1.7 kg
United Kingdom
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
10240 bytes
Max Units In A Stack
9
Routing Protocol
Encryption Algorithm
SSL, SSL 2.0, SSL 3.0, TLS 1.2
Authentication Method
Secure Shell v.2 (SSH2), RADIUS, TACACS+
Status Indicators
Power, RPS (Redundant Power Supply), console, link/activity/speed, USB, master, stack ID
8 x 10/100/1000 Base-T RJ-45 , 2 x 1/10GBase-X SFP+ , 1 x console RJ-45 , 1 x USB 2.0 Type A
Internal power supply
Power Redundancy
Optional
Power Consumption Stand by
5.6 Watt
4 rubber feet
1 x RJ-45 to RS-232 cable
Rack Mounting Kit
Included
MTBF
709,328 hours
IEC 61000-4-5, BSMI, FCC, IC, RCM, UKCA, EMC, VCCI, CB, cUL, LVD
United Kingdom
28 cm
18 cm
4.4 cm
1.7 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 10
Managed: Yes
Brand: D-Link
