The DSS-200G Series is a range of switches designed to meet the surveillance requirements of small, medium, and enterprise businesses.
Enhanced connectivity
With 8 PoE (Power over Ethernet) ports and 2 Gigabit SFP ports, this switch offers flexible connection options for a wide range of devices, ensuring high-speed data transfer and reliable power supply for PoE-enabled devices. -
Robust security features
Equipped with SSL encryption, ARP support, DoS attack prevention, and VLAN support, the D-Link DSS 200G-10MP provides a secure networking environment, safeguarding your data from unauthorized access and various types of cyber threats. -
High performance
Featuring a 20 Gbps switching bandwidth and a 14.88 Mbps forwarding bandwidth, this switch is designed to handle heavy data traffic, ensuring smooth and efficient network performance even during peak times. -
Energy efficient
Incorporating Green Technology and ENERGY STAR Ethernet (EEE), the D-Link DSS 200G-10MP minimizes power consumption, making it an eco-friendly solution for your networking needs. -
Easy management
Manageable via SNMP, ICMP, MIB, and more, this switch allows for easy setup and management, enabling you to optimize your network's performance and security with minimal effort.
- D-Link DSS 200G-10MP - switch - 8 ports - Managed - rack-mountable
- Switch - 8 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 (PoE) + 2 x Gigabit SFP
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 130 W
- Performance
- Switching bandwidth: 20 Gbps , Forwarding bandwidth: 14.88 Mbps
- Capacity
- Packet buffer size: 4.1 Mbit , Virtual interfaces (VLANs): 4094 , VLAN groups: 128 , QoS priority queues per port: 4
- MAC Address Table Size
- 8000 entries
- Jumbo Frame Support
- 10240 bytes
- Routing Protocol
- IGMPv2, IGMP, RSTP, STP
- Remote Management Protocol
- SNMP 2, SNMP, ICMP, MIB
- Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, QoS, reset button, Cable Diagnostics Function, fanless, LLDP support, DHCP client, built-in DIP switch, tagged VLAN, ONVIF support, ERPS, 6KV Surge protection, Voice VLAN, VLAN management, EEE, WRR, loopback detection, port-based VLAN, Unknown Storm Control, isolate mode, Green Technology, Asymmetric VLAN, mode button, UDP support, TCP support, Auto Surveillance VLAN, PD-Alive
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.1w, IEEE 802.3at, IEEE 802.3az
- Power
- AC 100-240 V (50 - 60 Hz)
- 28 cm x 18 cm x 4.4 cm
- 1.55 kg
- Localisation
- United Kingdom
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- PoE Budget
- 130 W
- Performance
- Capacity
- 8000 entries
- 10240 bytes
- Routing Protocol
- Encryption Algorithm
- SSL
- RAM
- 128 MB DDR3 SDRAM
- Flash Memory
- 32 MB
- Status Indicators
- Power, alarm, PoE, link/activity/speed
- 8 x 10/100/1000 Base-T RJ-45 PoE - 30 W , 2 x 1000Base-T SFP , 1 x alarm input RJ-45
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Stand by
- 10.4 Watt
- Included Accessories
- Rack mounting brackets
- Rack Mounting Kit
- Included
- MTBF
- 345,045 hours
- UL, BSMI, cUL, CB, IC, FCC, LVD
- Localisation
- United Kingdom
- 28 cm
- 18 cm
- 4.4 cm
- 1.55 kg
- -5 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
