D-Link 10-Port Gigabit Ethernet PoE+ Surveillance Switches
Quicklinx: J7L9WS00 Mfr#: DSS-200G-10MP/B
£168.60 ex VAT
£202.32 inc VAT
The DSS-200G Series is a range of switches designed to meet the surveillance requirements of small, medium, and enterprise businesses.
  • Enhanced connectivity
    With 8 PoE (Power over Ethernet) ports and 2 Gigabit SFP ports, this switch offers flexible connection options for a wide range of devices, ensuring high-speed data transfer and reliable power supply for PoE-enabled devices.
  • Robust security features
    Equipped with SSL encryption, ARP support, DoS attack prevention, and VLAN support, the D-Link DSS 200G-10MP provides a secure networking environment, safeguarding your data from unauthorized access and various types of cyber threats.
  • High performance
    Featuring a 20 Gbps switching bandwidth and a 14.88 Mbps forwarding bandwidth, this switch is designed to handle heavy data traffic, ensuring smooth and efficient network performance even during peak times.
  • Energy efficient
    Incorporating Green Technology and ENERGY STAR Ethernet (EEE), the D-Link DSS 200G-10MP minimizes power consumption, making it an eco-friendly solution for your networking needs.
  • Easy management
    Manageable via SNMP, ICMP, MIB, and more, this switch allows for easy setup and management, enabling you to optimize your network's performance and security with minimal effort.
D-Link DSS 200G-10MP - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE) + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
130 W
Performance
Switching bandwidth: 20 Gbps , Forwarding bandwidth: 14.88 Mbps
Packet buffer size: 4.1 Mbit , Virtual interfaces (VLANs): 4094 , VLAN groups: 128 , QoS priority queues per port: 4
MAC Address Table Size
8000 entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMPv2, IGMP, RSTP, STP
Remote Management Protocol
SNMP 2, SNMP, ICMP, MIB
Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, QoS, reset button, Cable Diagnostics Function, fanless, LLDP support, DHCP client, built-in DIP switch, tagged VLAN, ONVIF support, ERPS, 6KV Surge protection, Voice VLAN, VLAN management, EEE, WRR, loopback detection, port-based VLAN, Unknown Storm Control, isolate mode, Green Technology, Asymmetric VLAN, mode button, UDP support, TCP support, Auto Surveillance VLAN, PD-Alive
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.1w, IEEE 802.3at, IEEE 802.3az
AC 100-240 V (50 - 60 Hz)
28 cm x 18 cm x 4.4 cm
1.55 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
130 W
Performance
8000 entries
Jumbo Frame Support
10240 bytes
Routing Protocol
Encryption Algorithm
SSL
RAM
128 MB DDR3 SDRAM
Flash Memory
32 MB
Status Indicators
Power, alarm, PoE, link/activity/speed
8 x 10/100/1000 Base-T RJ-45 PoE - 30 W , 2 x 1000Base-T SFP , 1 x alarm input RJ-45
Internal power supply
Power Consumption Stand by
10.4 Watt
Rack mounting brackets
Rack Mounting Kit
Included
MTBF
345,045 hours
UL, BSMI, cUL, CB, IC, FCC, LVD
United Kingdom
28 cm
18 cm
4.4 cm
1.55 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: D-Link
