D-Link 10-Port Desktop Gigabit PoE+ Switch
Quicklinx: J7LFWS00 Mfr#: DGS-1010MP
£73.87 ex VAT
£88.64 inc VAT
The D-Link DGS-1010MP Gigabit PoE switch is an ideal solution for small offices and enterprise environments looking to expand the network with a set of PoE devices such as wireless access points, IP cameras, and IP phones. Built with small business and enterprise users in mind, the DGS-1010MP is a high-speed, flexible switch that features a fanless, quiet design so it can be conveniently placed anywhere in a working environment.
  • Superior performance
    Installation is quick and easy and requires no additional configuration. Support for auto MDI/MDI-X on all ports eliminates the need for crossover cables when connecting to another switch or hub. In addition, the DGS-1010MP features one Gigabit Ethernet and one SFP uplink port for high-speed connections to remote storage or for long distance fiber connections toan uplink network.
  • Compact and silent design
    The DGS-1010MP has a compact design, so that it can be deployed in any easily accessible location on the work floor, allowing you to power a set of PoE-powered devices while avoiding additional cable clutter.
D-Link DGS 1010MP - switch - 10 ports - unmanaged - rack-mountable
Switch - 10 ports - unmanaged
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 1 x 10/100/1000 (uplink) + 1 x 1000Base-X SFP (uplink)
Power Over Ethernet (PoE)
PoE+
PoE Budget
125 W
Performance
Switching capacity: 20 Gbps
Packet buffer size: 192
MAC Address Table Size
4K entries
Fanless, flow control, EEE, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, security slot (Kensington security lock compatible)
IEEE 802.3af, IEEE 802.3at, IEEE 802.3i, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3z, IEEE 802.3x, IEEE 802.3
28 cm x 18 cm x 4.4 cm
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
125 W
Performance
4K entries
Status Indicators
Link/activity/speed, power, status, PoE
8 x 1000Base-T RJ-45 PoE+ - 30 W , 1 x 1000Base-T RJ-45 uplink , 1 x 1000Base-X SFP uplink
Internal power supply
133.8 Watt
FCC Class A certified, VCCI Class A, CCC Class A, cUL, CB, CCC, LVD, RoHS
28 cm
18 cm
4.4 cm
0 - 95% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: D-Link
