D-Link 10-Port 10G Multi-Gigabit PoE++ Smart Managed Switch with 2 x 10G SFP+ Ports
Quicklinx: J7L6WS00 Mfr#: DXS-1210-10MP/B
Type: 10 Gigabit Ethernet
Ports: 8
Managed: Yes
POE: PoE++
Hurry, only 1 left in stock!
£568.09 ex VAT
£681.70 inc VAT
The D-Link DXS 1210-10MP is designed to offer robust performance for demanding network environments. With a switching capacity of 200 Gbps and a packet forwarding rate of 148.8 Mpps, this switch ensures efficient data handling and promotes seamless connectivity across devices. It supports a variety of features such as VLANs, IGMP snooping, and Jumbo Frame support, making it an ideal solution for modern networking needs.
Operating in extreme temperatures ranging from -5°C to 50°C and with humidity tolerance of 0 to 95% (non-condensing), the D-Link DXS 1210-10MP is well-suited for various environments. The device also features multiple remote management protocols, enabling easy monitoring and configuration. With a total of 8 10GBase-T ports and 2 10 Gigabit SFP+ connections, it offers versatility for connecting different devices while ensuring efficient power delivery through PoE++. This rack-mountable switch is a reliable choice for enhancing network performance and adaptability.
  • Robust switching capacity
    The D-Link DXS 1210-10MP features a switching capacity of 200 Gbps, ensuring quick and efficient data transfer across the network.
  • Advanced network management
    Equipped with multiple remote management protocols like SNMP and SSH, this switch allows for easy configuration and monitoring of network status.
  • Extensive connectivity options
    With 8 10GBase-T ports and 2 10 Gigabit SFP+ connections, the switch provides flexible connectivity choices for diverse network setups.
  • Adaptive environmental support
    Built to operate in temperatures from -5°C to 50°C and withstand high humidity, the D-Link DXS 1210-10MP performs reliably under varying conditions.
  • Poe++ capabilities
    The integrated PoE++ functionality delivers up to 370 W of power budget, allowing for seamless operation of devices without needing separate power sources.
D-Link DXS 1210-10MP - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
8 x 10GBase-T + 2 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE++
PoE Budget
370 W
Performance
Switching capacity: 200 Gbps , Packet forwarding rate: 148.8 Mpps
IGMP groups: 384 , Virtual interfaces (VLANs): 4000 , ARP entries: 768 , IPv4 routes (static): 64 , IPv6 routes (static): 64 , ACL rules: 256 , Access lists: 50
MAC Address Table Size
32K entries
Jumbo Frame Support
10000 bytes
Routing Protocol
IGMP, IGMPv2, IGMPv3, MLD, MLDv2
Remote Management Protocol
SSH, CLI, Telnet, TFTP, SNMP 1, SNMP 2c, SNMP 3, RMON 1, RMON 2
Store and forward, IGMP snooping, MLD snooping, LLDP support, STP support, RSTP support, MSTP support, flow control, port mirroring, Jumbo Frames support, loopback detection, ERPS, DSCP support, IPv6 support, WRR queuing, ARP support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Safeguard Engine, DHCP server, Port Security, MDI/MDI-X switch, SNMP trap, BOOTP support, DHCP client, Syslog support, SNTP support, D-Link Green Technology, 6KV PoE surge protection, 2 fans, Cable Diagnostics Function, DoS attack prevention, Duplicated Address Detection, fast PoE, PD-Alive, perpetual PoE
IEEE 802.1ab (LLDP), IEEE 802.1D, IEEE 802.1w, IEEE 802.1s, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3 at, IEEE 802.3bt
AC 100-240 V
44 cm x 25 cm x 4.4 cm
3.7 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
PoE++
PoE Budget
370 W
Performance
32K entries
Jumbo Frame Support
10000 bytes
Routing Protocol
Encryption Algorithm
SSL, TLS, TLS 1.0, TLS 1.1, TLS 1.2, TTLS, PEAP
Authentication Method
RADIUS, Extensible Authentication Protocol (EAP)
Status Indicators
Console, fan, link/activity/speed, PoE max, power
8 x 10GBase-T RJ-45 , 2 x Gigabit SFP / 10 Gb SFP+ SFP+ , 1 x console RJ-45
Internal power supply
AC 100-240 V
BSMI, CB, TLS, cUL, FCC, VCCI, IEEE 802.3af, IEEE 802.3bt, IEEE 802.3at, RCM, IC, RFC768 UDP, RFC792, RFC793 TCP, RFC826 ARP, RFC2021, RFC2460, RFC2461, RFC2462, RFC2463, RFC2464, RFC2474, RFC2571, RFC2572, RFC2573, RFC2574, RFC2618, RFC2674, RFC2893, RFC2925, RFC3513, RFC4293, RFC4884, RFC4861, RFC4862, RFC4443, RFC3260, RFC4363, RFC1757, RFC2819, RFC4213, RFC4291
United Kingdom
44 cm
25 cm
4.4 cm
3.7 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 8
Managed: Yes
POE: PoE++
Brand: D-Link
Price Range Ex VAT: £500 - £750
