D-Link 1-port Mini-GBIC SFP to 1000BaseLX
Quicklinx: GFSBWS00 Mfr#: DIS-S310LX
£37.95 ex VAT
£45.54 inc VAT
The D-Link DIS S310LX SFP (mini-GBIC) transceiver module is designed for high-speed data transmission, supporting Ethernet 1000Base-LX, making it compatible with a wide range of networking equipment. With a data transfer rate of 1 Gbps and the ability to operate over distances up to 10 km, it is a suitable choice for organizations looking to expand their network's reach without compromising on speed or reliability. The module's robust design allows it to function in extreme temperatures ranging from -40°C to 85°C, ensuring reliable performance in any environment. Whether you're looking to enhance your current network infrastructure or build a new one from the ground up, the D-Link DIS S310LX offers a blend of performance, durability, and ease of integration.
  • Enhanced connectivity
    The D-Link DIS S310LX is equipped with an LC single-mode connector, ensuring a reliable, high-speed connection. Its compatibility with Ethernet 1000Base-LX cabling allows for seamless integration into existing network infrastructures, making it a suitable solution for extending network reach.
  • Robust performance
    Designed to operate in a wide range of environmental conditions, this SFP (mini-GBIC) transceiver module can withstand temperatures from -40°C to 85°C. Its durability ensures uninterrupted performance, even in the most challenging climates.
  • Long-distance operation
    With a maximum transfer distance of 10 km, the D-Link DIS S310LX is perfect for applications requiring long-distance data transmission. This feature, combined with a data transfer rate of 1 Gbps, makes it a suitable choice for expanding network coverage over large areas.
D-Link DIS S310LX - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
1GbE
Max Transfer Distance
10 km
Plug-in module
Wired
Cabling Type
1000Base-LX
1GbE
Data Transfer Rate
1 Gbps
10 km
1 x Ethernet 1000Base-LX - LC single-mode
-40 °C
85 °C
Brand: D-Link
