D-Link 1-Port Gigabit PoE Injector
Quicklinx: 9H8SWS00 Mfr#: DPE-101GI
£27.35 ex VAT
£32.82 inc VAT
The DPE-101GI Power Over Ethernet (PoE) Injector is designed to supply a power and data connection to PoE devices such as an IP Camera or Wireless Access Point.
The DPE-101GI gives you the ability to mount your PoE device virtually anywhere in a building, such as on ceilings or near entryways, by eliminating the need for a nearby power outlet and attached power supply. D-Link’s DPE-101GI combines electrical power with a Gigabit network connection and produces a Gigabit Power over Ethernet (PoE) signal, allowing a single Ethernet cable to carry both data and power to a device.
Cost Efficient Flexibility
Deploying the DPE-101GI saves both installation costs and equipment costs, allowing a single RJ-45 Ethernet cable to carry both power and data to each device. This reduces cables, eliminates the need for dedicated electrical outlets on the wall, ceiling, or other unreachable place, and most of all, reduces installation time.
The Power over Ethernet solution frees IP surveillance cameras and wireless AP deployments from the restrictions of power outlet locations.
High Speed Connectivity
The DPE-101GI Power Over Ethernet (PoE) Injector is designed to be deployed in situations where high bandwidth is demanded. Examples where the DPE-101GI is ideal include powering network devices such as wall mounted PTZ (Pan, Tilt & Zoom) network cameras, ceiling mounted PTZ dome network cameras, video and voice over IP (VoIP) telephones, and multichannel (11a/b/g/n) wireless LAN access points.
D-Link DPE-101GI PoE Gigabit injector - PoE injector
PoE injector - external
Output connectors
1 x RJ-45
Power adapter
D-Link DAP-2660; AirPremier N PoE Access Point with Plenum-rated Chassis DAP-2360
1 x RJ-45
1 x Gigabit LAN - RJ-45
Power adapter
Power cable - external
D-Link DAP-2660 , D-Link AirPremier N PoE Access Point with Plenum-rated Chassis DAP-2360
9H8S C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.25
9H8S C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.00
Type: Power Injector
Brand: D-Link
