D-Link 1-Port Gigabit 30W PoE Splitter
Quicklinx: D0X3WS00 Mfr#: DPE-301GS
Type: PoE Kit
£28.31 ex VAT
£33.97 inc VAT
The DPE-301GS PoE splitter is used with end devices such as wireless access points, IP cameras and VoIP phones that don't natively support PoE, but rather require DC power input. It receives PoE power on a network cable from a PoE switch or midspan injector, and splits the Ethernet and DC power into two separate cables. One cable provides the DC power, and the other cable provides the Ethernet signal. The DPE-301GS PoE splitter has two 10 / 100 / 1000 RJ-45 ports. One port is for PoE input, which is the network connection and is usually connected to a remote PoE switch or injector. The other port is for LAN output, which is the connection that provides the Ethernet signal to the end device.
  • Versatile compatibility
    Designed to seamlessly integrate with PC systems, the DPE-301GS PoE splitter enhances connectivity options by providing a reliable Gigabit LAN connection through its RJ-45 connector. This feature ensures high-speed data transfer rates, making it an ideal solution for various networking environments.
  • Flexible power options
    The DPE-301GS offers versatile power output options, including 5 V, 9 V, and 12 V, to accommodate a wide range of devices. This flexibility ensures that connected devices receive the correct voltage, enhancing their performance and reliability.
  • Robust environmental adaptability
    Engineered to operate efficiently across a broad range of temperatures from 0°C to 60°C and humidity levels from 5 to 95% (non-condensing), the DPE-301GS is built to withstand challenging environmental conditions, ensuring reliable performance in diverse operating scenarios.
D-Link DPE-301GS - PoE splitter
PoE splitter - external
98 g
Output Voltage
5 / 9 / 12 V
Output connectors
1 x power DC jack
10.98 cm x 6.22 cm x 2.45 cm
1 x power DC jack
Output Voltage
5 / 9 / 12 V
1 x Gigabit LAN - RJ-45
Network cable , Power cable
UL, VCCI, BSMI, cUL, CB, CCC, IC, FCC, RoHS, KCC, ANATEL, RCM
60 °C
5 - 95% (non-condensing)
10.98 cm
6.22 cm
2.45 cm
98 g
Type: PoE Kit
Brand: D-Link
