Charge all your Micro-USB devices quickly and safely with 12W charging. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
This cable allows you to easily charge or sync all your micro USB devices wherever you are.
Able to withstand daily use, bends and drops.
