Featuring Online Double Conversion UPS topology, the Online Series provides the highest level of power protection and a guaranteed quality power supply to demanding businesses who value versatility, flexibility, manageability and performance. performance. Numerous engineering excellences showcase in this enterprise-level application including economy mode setting, smart battery management, and generator mode setting, which further enhance its overall performance and capability. With the perfect zero transfer time, the Online Series ensures the continuous and seamless pure sine wave power to all mission-critical devices.
This product comes with remote management capabilities which include the PowerPanel SNMP/HTTP network management card, enabling users to perform comprehensive network management and monitoring including unattended-shutdown, event logging, reporting, and notifications.
Online Double Conversion topology
Online (Double Conversion) topology provides an extra layer of insulation from power problems. This is achieved by continuously operating off battery power and having zero transfer time during power outages. Online topology also stabilizes output frequency and voltage, and eliminates any line noise that may be apparent in industrial settings or when operating off generator power. -
Pure sine wave output
For applications that require pure sine wave power, CyberPower provides UPS models with true sine wave output, also known as pure sine wave. They are designed for electronic devices that have Power Factor Correction (PFC) power supplies as well as for small AC motors and other devices that need true sinewave power in order to function properly.
- CyberPower Smart App Online OLS3000E - UPS - 2700 Watt - 3000 VA
- UPS - active Power Factor Correction (PFC) - external
- 28.2 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 208/220/230/240 V ± 3%
- Power Capacity
- 2700 Watt / 3000 VA
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 4 x power IEC 60320 C13 , 1 x terminal block , 1 x power IEC 60320 C19
- Battery
- Lead Acid expandable - 8.5 Ah
- Battery Form Factor
- Internal
- Batteries Qty
- 6
- Run Time (Up To)
- 4 min at full load
- Networking
- RS-232, USB
- Black
- System Requirements
- Apple MacOS, Linux, Microsoft Windows 2000 Professional, Microsoft Windows 98/ME, Microsoft Windows Vista / XP / 7, Microsoft Windows 2003, Microsoft Windows Server 2008
- 19.6 cm x 41.6 cm x 33.7 cm
- 3-year warranty
- Battery Enclosure Type
- Internal
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 190 - 300 V
- Frequency Provided
- 50/60 Hz
- Input Voltage Margin
- ± 10%
- Frequency Required
- 40 - 70 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 208/220/230/240 V ± 3% - 50/60 Hz
- Power Capacity
- Dataline Surge Protection
- Network/phone line - RJ-45/RJ-11
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 440 Joules
- Circuit Protection
- Circuit breaker
- Expandable
- Quantity
- 6
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 8.5 Ah
- Run Time (Up To)
- 4 min at full load , 14 min at half load
- Recharge Time
- 5 hours
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off)
- Expansion Slots
- 2 (total) / 2 (free) x Expansion Slot
- Equipment Protection Value
- 100000 Euros
- Audible alarm, LCD display, built-in maintenance bypass, LED indicators, overload protection, cold-start function
- PCT, ISO 14001, RoHS, ISO 9001:2000
- Software Included
- PowerPanel Business Edition
- OS Required
- Limited warranty - batteries - 3 years
- 0 °C
- 40 °C
- 0 - 90%
- 19.6 cm
- 41.6 cm
- 33.7 cm
- 28.2 kg
- Shipping Width
- 29.5 cm
- Shipping Depth
- 51.9 cm
- Shipping Height
- 45.8 cm
- Shipping Weight
- 30.4 kg
