Cyberlink PhotoDirector 7 Ultra makes photo editing easier and faster with an extreme blend of powerful features. Versatile tools such as layer-based editing, pro-level blur effects, and color presets open up new avenues of creativity. Correct lens distortions, remove unwanted objects, and touch-up faces to achieve the perfect shot. Intuitive management tools and sophisticated editing options make PhotoDirector a complete end-to-end solution for photographers.
A Photographer's Best Friend
There’s joy in taking pictures. Whether you are photographing a family member or a landscape, there’s nothing quite like preserving a moment forever with a picture. PhotoDirector helps you make the most of your photo collection. The addition of new layer-based editing now lets you do even more. Create photo compositions with multiple images, text and visual elements, and select from one of the 14 layer blending modes to achieve almost any artistic effect you can visualize.
Filters, Blurs and Effects
An array of features let you easily adjust and enhance your shots, to turn them into spectacular photos. Create stunning panoramas, dramatic HDR effects, and remove unwanted objects. New radial filter and blur tools let you highlight a specific area of a photo, or to manually create a vignette effect.
Explore New Creative Options
Layers are an integral tool in advanced image editing projects. PhotoDirector now lets you create and edit layers in images, with 14 different layer blending modes. Layer management tools include: rename, duplicate, delete, adjust, convert and merge, letting you make the exact modifications needed to create a visual tour de force.
Easily Touch-up Figures and Faces
Precise tools let you accurately apply adjustments to body contours and skin tones. Quickly eliminate imperfections with Eye Blinger, Wrinkle Removal, Skin Smoother, and Tooth Brush tools. Perfect your subject’s appearance with new
Face Shaper, Eye Bag Remover, Eye Enlarger, and Shine Remover features.
Add or Remove Objects in Photos
PhotoDirector lets you easily extract objects from images and transfer them as overlays onto other photos. The Content-Aware Removal tool lets you erase unwanted objects quickly and easily. PhotoDirector fills the space left by the deleted object with image details from the surrounding area, for a seamless result.
Minimum System Requirements
WINDOWS
-Intel Pentium D 3.0 GHz CPU with hyper-threading or equivalent AMD CPU
-Intel Corei7 or AMD Phenom II X4 recommended for 64 bit program
Screen Resolution
1024 X 768, 16-bit color or above
Operating System
Microsoft Windows 10, 8/8.1, 7, Vista (SP2).
2 GB
Hard Disk Space
1 GB
Other
Internet connection required for initial software activation, DirectorZone, and social media services.
MAC
Multi-core Intel processor with 64-bit support
Screen Resolution
1024 x 768 display
Operating System
Mac OS X v10.7 or later
2 GB required
Hard Disk Space
1 GB of available hard-disk space
Other
