The Cyber Snipa SONAR Gaming Headphones are the latest development in the field of tactical communications. With true 5.1 surround sound you can stalk your enemies from across the map by the sound of their footsteps!
The SONAR headphones feature 8 individual speakers (4 in each ear cup including a subwoofer) for highly accurate positional audio. The Cyber Snipa 3D positional audio software enables individual adjustment of all channels, virtual speaker placement and a wide range of effects. In concert with the dual subwoofer units and bass enhancement, you can really feel the action!
The SONAR headphones possess a plethora of high tech features - noise canceling boom microphone with flexible mounting, inline multimedia controls and folding construction allowing for transportation in a compact form.
- Cyber Snipa SONAR 5.1 - headset
- Product Type
- Headset - 5.1 channel - wired
- Recommended Use
- Computer
- Headphones Form Factor
- Full size binaural
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Surround Sound
- Audio Specifications
- Sensitivity 108 dB
- Signal-To-Noise Ratio
- 50 dB
- Microphone
- Boom
- Product Type
- 19 cm
- 9 cm
- 29 cm
- Recommended Use
- Computer
Audio Output
- Dynamic
- Wired
- Sound Output Mode
- Surround Sound
- 50 dB
- Sensitivity
- 108 dB
- In-Cord Volume Control
Microphone
- Boom
- Sensitivity
- -39 dB
- Impedance
- 2.2 Ohm
- Audio Input Details
- Uni-directional
- Connector Type
- USB (4 PIN USB Type A)
- Cable Details
- USB cable - 3 m
Customer reviews
Write a review for the Cyber Snipa Sonar 5.1 Headset here!
Good And Bad
Reviewed by Luke Finch. Review Posted 14/02/2009
Well, bought the headset thinking it would actually be a good headset for the price, ooo how wrong i was...
I have had bsod about 6 times now, i can't get the rear two speakers to work, mic won't work in game and the settings constantly configuring themselves such as muting the mic etc!
Not worth the money what so ever, go out and buy a Razer Barracuda or Creative Fatal1ty Headset instead cause the Sonar is not worth the hassle!
Overall
Ease of use
Value for money
CyberSnipa Sonar 5.1
Reviewed by Anonymous Review Posted 27/01/2009
Be Aware these headphone do not work with VISTA! CyberSnipa will not be able to help apart from stating the obvious
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
