Cyber Snipa Game Pad V2 Black
Quicklinx: 50PRWS00 Mfr#: CSGPBK01R
Anyone who has played FPS games for long periods of time will tell you that a standard keyboard is just too cramped for precision control and long term game play. The Game Pad can take you to the highest level of skill and help you to be the best in the game.
Position it alongside your mouse and mouse pad in a far more flexible way that optimizes game space. The intuitive key layout reduces the learning curve and improves game control, speed and accuracy.
  • Automated FPS functions
    FPS game keys are automatically mapped.
  • Map - it the way you like it
    37 keys can be mapped to user preference.
  • Die Less
    It is easy to use WASD keys.
  • Plug and play
    USB plug and play - no drivers required.
  • Glow in the dark
    Side rail light is designed for a blue glow.
  • Save your wrist
    Detachable non-slip palm rest.
  • Get out of My Way
    It gives you more desk space.
  • Sound explosion
    It is built in volume control.
Flexiglow Cyber Snipa Game Pad V2 - keyboard - black Input Device
Keyboard
Backlit
USB
Wired
Keys Qty
37
Hot Keys Function
Programmable, volume, mute
Detachable wrist rest
15.3 cm x 23.5 cm x 2.4 cm
380 g
Keyboard
Backlit
USB
Keys Qty
37
Hot Keys Function
15.3 cm
23.5 cm
2.4 cm
380 g
1 x USB - 4 pin USB Type A
1 x USB cable
Plug and Play
Microsoft Windows Vista, Microsoft Windows Vista (64-bit versions)
