CTOUCH Leddura 86" 3840x2160 4K LED Large Format Display
Quicklinx: D922WS00 Mfr#: 10051886
Get everyone connected through touch! Make a dazzling first impression, interact with your audience. What you see is the flawless presentation of the facts.
CTOUCH Leddura 2Share - 86" Class (85.6" viewable) LED-backlit LCD display - 4K
LED-backlit LCD flat panel display with built-in interactive whiteboard, touchscreen (multi touch)
Diagonal Class
86"
Diagonal Size
85.6"
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN
PC Interface
VGA (HD-15), DisplayPort
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
Speaker System
2 speakers
Sound Effects
JBL Live Stage
USB
2 ports
Remote control, docking station, electronic touch pen, visitor USB tokens
Energy Class
Class A+
Power Consumption (On mode)
214 W
Energy Consumption per Year
312 kWh
199.36 cm x 12.6 cm x 117.76 cm
112 kg
3-year warranty
Energy Class
Class A+
214 W
312 kWh
Diagonal Class
86"
Diagonal Size
85.6"
Combined With
Built-in interactive whiteboard, touchscreen (multi touch)
Series
2Share
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Backlight off mode, Dynamic Picture Mode, user mode, soft mode, Standard mode
Dimensions
Without stand
199.36 cm
12.6 cm
117.76 cm
112 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Direct-lit LED
Coating
Anti-reflection
Image Contrast Ratio
1200:1
Brightness
350 cd/m²
Touchpoints Qty
32
Display Menu Language
English
Open Pluggable Specification slot, integrated whiteboard functions, 10-bit Video Processing, Surface Light Wave, built-in Wi-Fi router, live quad picture view
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Audio System
Surround Mode
Sound Effects
JBL Live Stage
Speaker System
2 speakers
Output Power / Total
80 Watt
Echo cancellation, JBL 3-way sound system, JBL Far Field microphone, Voice Logic technology, Sonique technology, advanced ambient noise reduction
Speakers
2 x speaker - 40 Watt
Driver Details
Speaker: tweeter driver , Speaker: mid-range driver , Speaker: woofer driver
Network & Internet Multimedia
Functionality
Whiteboard
Wi-Fi, LAN
Wi-Fi Protocol
802.11b, 802.11g, 802.11n, 802.11a, 802.11ac
Connector Type
2 x HDMI input , DisplayPort input , 3 x VGA input , VGA output , Composite video/audio input , 3 x audio line-in , SPDIF output , USB 2.0 , USB , RS-232C , LAN , Headphones , HDMI output , Microphone , USB
Docking station, electronic touch pen, visitor USB tokens
USB cable , HDMI cable
ISO 9001, ISO 14001, RoHS, HDCP 2.2
Power supply
Power Consumption Sleep
0.5 Watt
On / Off Switch
Limited warranty - 3 years
Width (Shipping)
211.4 cm
Depth (Shipping)
29 cm
Height (Shipping)
145.6 cm
Weight (Shipping)
128 kg
