Leddura 2Meet is developed to make collaboration more accessible and more interactive in any meeting room. Everything you need for an effective meeting comes together in one system: wireless content sharing, whiteboarding, video conferencing, and direct insight into the availability of meeting rooms. Get to know the ideal solution for agile and lean teams.
Wireless content sharing from any device
Share your content wirelessly and bring interaction to your team. If you are using iPhones, Android, Mac or PC, you can now easily display 4 devices on the touchscreen at the same time. All in a secure and reliable environment. -
Whiteboarding: make notes directly on the screen
Simply start the whiteboarding feature with one press of the button. Everyone in the meeting can simultaneously write, annotate, share files and add new pages. -
Ideal match for video conferencing
The Leddura 2Meet touchscreen is specifically designed to integrate seamlessly with Skype for Business. This makes using this touchscreen easy and trustworthy. The touch functionality allows simple and interactive editing of documents and content during meetings. Whether you want to call with Skype for Business users, H323 devices, or phone numbers: video conferencing with colleagues around the world has never been so easy. -
Room booking: easily make a reservation and get direct insight into availability
Schedule a meeting in Outlook, then go to the meeting room and start the meeting with 1 press of the button. Is there a meeting room free? You can also easily make a reservation from the screen. Did you forget to cancel a meeting? No problem, if the room is not being used, Leddura 2Meet will release it automatically after 15 minutes.
- CTOUCH Leddura 2Meet 65" LED-backlit LCD display - 4K - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with built-in interactive whiteboard, touchscreen (multi touch)
- Diagonal Class
- 65"
- Commercial Use
- Yes - interactive
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- VGA (HD-15), DisplayPort
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Sound Effects
- JBL Live Stage
- USB
- 2 ports
- Included Accessories
- Remote control, docking station, electronic touch pen, visitor USB tokens
- Energy Class
- Class A+
- Power Consumption (On mode)
- 123 W
- Energy Consumption per Year
- 179 kWh
- Dimensions (WxDxH) - without stand
- 151.36 cm x 11.6 cm x 90.16 cm
- 52 kg
- 3-year warranty
- Product Type
- Energy Class
- Class A+
- 123 W
- 179 kWh
- Diagonal Class
- 65"
- Commercial Use
- Yes - interactive
- Combined With
- Built-in interactive whiteboard, touchscreen (multi touch)
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- Modes
- Backlight off mode, Dynamic Picture Mode, user mode, soft mode, Standard mode
- Dimensions
- Without stand
- 151.36 cm
- 11.6 cm
- 90.16 cm
- 52 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Direct-lit LED
- Coating
- Anti-reflection
- Image Contrast Ratio
- 4000:1
- Brightness
- 350 cd/m²
- Touchpoints Qty
- 32
- Display Menu Language
- English
- Open Pluggable Specification slot, integrated whiteboard functions, 10-bit Video Processing, Surface Light Wave, built-in Wi-Fi router
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Surround Mode
- Sound Effects
- JBL Live Stage
- Speaker System
- 2 speakers
- Output Power / Total
- 80 Watt
- Echo cancellation, JBL 3-way sound system, JBL Far Field microphone
- Speakers
- 2 x speaker - 40 Watt
- Driver Details
- Speaker: tweeter driver , Speaker: mid-range driver , Speaker: woofer driver
Network & Internet Multimedia
- Functionality
- Whiteboard
- Connectivity
- Wi-Fi, LAN
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n, 802.11a, 802.11ac
- Connector Type
- 2 x HDMI input , DisplayPort input , 3 x VGA input , VGA output , Composite video/audio input , 3 x audio line-in , SPDIF output , 2 x USB 2.0 , USB , RS-232C , LAN , HDMI output
- Docking station, electronic touch pen, visitor USB tokens
- Cables Included
- USB cable , HDMI cable
- Plug and Play, ISO 9001, ISO 14001, RoHS, HDCP 2.2
- Power Device
- Power supply
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- Limited warranty - 3 years
- Width (Shipping)
- 163.7 cm
- Depth (Shipping)
- 23.4 cm
- Height (Shipping)
- 108.7 cm
- Weight (Shipping)
- 61 kg
