Crumpler Private Surprise Bag for Laptops up to 15" - Black
HUGE SAVINGS! ALL CRUMPLER NOW REDUCED!!
Quicklinx: 90JLWS00 Mfr#: PS-L-001
Surprise! Bags can be sexy, sleek and tough as nails. The exterior combines original 1000d Chicken Tex Supreme hyper performance fabric and a rubber-dipped bottom. The Private Surprise mixes functionality and design seamlessly (but with seams, naturally). The Private Surprise laptop 15" W features external zip pockets, easy grab handles and a smart laptop pouch. Flexible loops on the laptop pouch mean that the laptop can be secured more firmly.
  • Original 1000d Chicken Tex Supreme
    Everyone has heard the urban myth that Chickens can't fly. Well Crumpler's can, and they also lay golden eggs. The chickens fly around finding Crumpler's official super high performance 1000d fabric which is lightweight, durable, resists tearing and is quick drying. Made with nylon thread which is air treated, this gives the final fabric its classic rough and fuzzy texture. This texture is what makes Chicken Tex Supreme so incredibly resistant to abrasion.
  • Ripstop lining
    Made from 330d treated nylon. Ripstop lining is a fabric that is woven with a thicker thread to prevent the spreading of tears or punctures. Even if you manage to shove a pen through the lining of Crumpler's bags, the tear or hole will not get any bigger than the 7 mm grid because of the grid of thicker thread patterns you can see in the material.
  • 2-sided tuck-in third leg stabilizer
    The third leg needs securing and the stabilizer does just that. Each buckle has its own tuck in, meaning you are able to hide the buckles away when they are not in use.
  • Single Hand buckle
    The reason for its name comes from the functionality, where you can quite literally reach down with one hand 'single hand', flick the buckle up and adjust your bag in one swift, easy movement. The Quick Flick buckle is made from polyamide or polyacetal.
Crumpler Private Surprise L - notebook carrying case
Notebook carrying case
Product Material
Ripstop, 1000D ChickenTex Supreme
50 cm x 16.5 cm x 30 cm
Notebook Compatibility
15"
Waterproof, adjustable shoulder strap, external zip pocket, Single Hand buckle
Carrying Strap
Hand grip, shoulder carrying strap
30 years warranty
Product Material
50 cm
16.5 cm
30 cm
15"
Notebook Compatibility Dimensions
38.5 cm x 4 cm x 26.5 cm
Carrying Strap
Limited warranty: - 30 years
