Protect your memories with the Crucial X8 Portable SSD - back up important photos, videos, and documents with up to 2TB capacity. Expand storage on your PS4, Xbox One, iPad Pro, Android device, or simply free up space on your computer quickly with speeds up to 1050MB/s. The Crucial X8 runs up to 1.8x faster than other portable SSDs and up to 7.5x faster than portable HDDs. Store with confidence on the Crucial X8.
Phenomenal speed
Wherever you are, access your games, photos, and videos quickly - even offline. -
Works with a broad range of devices
Increase storage capacity for nearly any computer, tablet, phone, or console. -
Built for tough conditions
Indoors or outdoors, at home or off the grid, the X8 is manufactured to be durable, rugged, and compact. Tested against extreme temperatures, shock, vibration, you can trust that your drive will withstand the elements. -
Sleek style
Form meets function with the Crucial X8. Built with a unibody core of anodized aluminum, the case not only looks and feels great, but dissipates heat efficiently to maximize performance.
- Crucial X8 - SSD - 2 TB - USB 3.2 Gen 2
- Solid state drive - external (portable)
- Capacity
- 2 TB
- Interface
- USB 3.2 Gen 2 - USB-C
- Data Transfer Rate
- 10.0 Gbps (USB 3.2 Gen2)
- Shock resistant, rugged
- Power Source
- USB bus
- 3-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.2 Gen 2
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 1050 MB/s
Expansion & Connectivity
- 1 x USB 3.2 Gen 2 - 24 pin USB-C
- Power Source
- USB bus
- OS Required
- Apple MacOS X, Android, Windows 8.1, Windows 10
- Cables Included
- 1 x USB-C 3.2 Gen 2 cable - external , 1 x USB-C to USB-A adapter - external
- UL, TUV, BSMI, RoHS, WEEE, RCM
- Limited warranty - 3 years
