Crucial X8 1TB Portable SSD
Quicklinx: G65BWS00 Mfr#: CT1000X8SSD9
Protect your memories with the Crucial x8 portable SSD - back up important photos videos and documents with up to 1TB Capacity Expand storage on your PS4, XBOX one, iPad Pro, Android device or simply free up space on your computer quickly with speeds up to 1050 MB/s The Crucial x8 runs up to 1 8x faster than other portable SSDs and up to 7 5x faster than portable HDD Store with Confidence on the Crucial x8.
Mb/s Speed measured as maximum sequential performance of device as measured by Crucial on a high-performance desktop computer with crystal disk mark (version 6. 0. 2 for x64) your performance may vary Comparative speed claims measured as maximum sequential performance of similarly situated portable SSDs mainstream portable HDD and mainstream USB flash drives from vertically-integrated manufacturers selling under their own brands as of June 2019.
Compatibility may vary and may be contingent on device formatting and host capabilities.
Latest firmware may be required for operation.
Compatible Android devices must be able to work with USB mass storage over OTG Operating system updates and reformatting may be required.
IPad OS 13 required for the Crucial x8 to work with iPad Pro devices with USB-C port 6 Up to 7 5ft/2M without impact to data on drive on a carpeted floor.
  • Phenomenal speed
    Wherever you are, access your games, photos, and videos quickly - even offline.
  • Works with a broad range of devices
    Increase storage capacity for nearly any computer, tablet, phone, or console.
  • Built for tough conditions
    Indoors or outdoors, at home or off the grid, the X8 is manufactured to be durable, rugged, and compact. Tested against extreme temperatures, shock, vibration, you can trust that your drive will withstand the elements.
  • Sleek style
    Form meets function with the Crucial X8. Built with a unibody core of anodized aluminum, the case not only looks and feels great, but dissipates heat efficiently to maximize performance.
Crucial X8 - SSD - 1 TB - USB 3.1 Gen 2
Solid state drive - external (portable)
1 TB
USB 3.1 Gen 2 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.1)
Shock resistant, rugged
Power Source
USB bus
3-year warranty
1 TB
USB 3.1 Gen 2
Performance
Interface Transfer Rate
10.0 Gbps (USB 3.1)
Max Data Transfer Rate
1050 MB/s
Expansion & Connectivity
1 x USB 3.1 Gen 2 - 24 pin USB-C
Power Source
USB bus
Apple MacOS X, Microsoft Windows, Android
1 x USB-C 3.1 cable - external , 1 x USB-C to USB-A adapter - external
Limited warranty - 3 years
