Crucial X6 2TB Portable SSD
Quicklinx: G659WS00 Mfr#: CT2000X6SSD9
Form Factor: [N/A]
Capacity: 2TB
Interface: USB 3.1
£97.23 ex VAT
£116.67 inc VAT
How much content can you hold with your fingertips? With the Crucial X6 Portable SSD, the answer is: A lot! Whether you're downloading videos for off-line travel, organizing family photos, collaborating with classmates, or heading off on a great adventure, the Crucial X6 features [1TB/2TB] of portable storage capacity1 and is ready to go wherever you do.
  • Portable design
    The Crucial X6 boasts a compact and lightweight form factor, making it an ideal companion for users on the go. Its external, portable design ensures that you can carry your important files, photos, and videos with you wherever you travel, without the hassle of a bulky setup.
  • High-speed connectivity
    Equipped with a USB-C 3.2 Gen 2 cable, the Crucial X6 offers fast data transfer speeds, allowing for quick and efficient file transfers. This feature ensures that users can move large files or perform backups in a fraction of the time it takes with older, slower connections.
  • Durable and reliable
    Designed to withstand the rigors of daily use, the Crucial X6 features a shock-resistant build that protects your data from accidental drops and bumps. This durability, combined with compliance to multiple standards including BSMI, KCC, RCM, RoHS, UL, and WEEE, ensures a reliable storage solution for your valuable data.
Crucial X6 - SSD - 2 TB - USB 3.1 Gen 2
Solid state drive - external (portable)
2 TB
USB 3.1 Gen 2 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.1 Gen 2)
Shock resistant
Power Source
USB bus
Enclosure Colour
69 mm x 11 mm x 64 mm
42 g
3-year warranty
2 TB
USB 3.1 Gen 2
Shock resistant
69 mm
11 mm
64 mm
42 g
Performance
Interface Transfer Rate
Internal Data Rate
540 MBps
Expansion & Connectivity
1 x USB 3.1 Gen 2 - 24 pin USB-C
Power Source
USB bus
Apple MacOS X, Microsoft Windows, Android
1 x USB-C 3.2 Gen 2 cable - external , 1 x USB-C to USB-A adapter - external
UL, BSMI, RoHS, KCC, WEEE, RCM
Enclosure Colour
Package Type
Retail
Limited warranty - 3 years
10 - 80%
Shock Tolerance (operating)
3.1 g
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (operating)
5-800 Hz
Form Factor: [N/A]
Capacity: 2TB
Interface: USB 3.1
Brand: Crucial
