How much content can you hold with your fingertips? With the Crucial X6 Portable SSD, the answer is: A lot! Whether you're downloading videos for off-line travel, organizing family photos, collaborating with classmates, or heading off on a great adventure, the Crucial X6 features [1TB/2TB] of portable storage capacity1 and is ready to go wherever you do.
- Crucial X6 - SSD - 2 TB - USB 3.1 Gen 2
- Solid state drive - external (portable)
- Capacity
- 2 TB
- Interface
- USB 3.1 Gen 2 - USB-C
- Data Transfer Rate
- 10.0 Gbps (USB 3.1 Gen 2)
- Shock resistant
- Power Source
- USB bus
- Enclosure Colour
- Black
- 69 mm x 11 mm x 64 mm
- 42 g
- 3-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.1 Gen 2
- Shock resistant
- 69 mm
- 11 mm
- 64 mm
- 42 g
Performance
- Interface Transfer Rate
- Internal Data Rate
- 540 MBps
Expansion & Connectivity
- 1 x USB 3.1 Gen 2 - 24 pin USB-C
- Power Source
- USB bus
- OS Required
- Apple MacOS X, Microsoft Windows, Android
- Cables Included
- 1 x USB-C 3.2 Gen 2 cable - external , 1 x USB-C to USB-A adapter - external
- UL, BSMI, RoHS, KCC, WEEE, RCM
- Enclosure Colour
- Black
- Package Type
- Retail
- Limited warranty - 3 years
- 40 °C
- 10 - 80%
- Shock Tolerance (operating)
- 3.1 g
- Shock Tolerance (non-operating)
- 1500 g @ 0.5 ms
- Vibration Tolerance (operating)
- 5-800 Hz
