Whether you're at work, in the game, or on the go, ordinary boot-up speeds can frustrate your plans. Good thing the Crucial P2 SSD really flies. With plenty of storage and performance accelerated by NVMe technology, the P2 has the speed and dependability you need to explore your computer's potential.
Do more, wait less
Experience the NVMe difference. The Crucial P2 unlocks the performance of your computer, delivering shorter load times and faster data transfers. -
Lasting reliability
Backed by thousands of validation hours and dozens of qualification tests. -
Peace of mind
You get performance optimization, data security, and firmware updates.
- Crucial P2 - SSD - 250 GB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 250 GB
- Form Factor
- M.2 2280
- Interface
- TRIM support, Error Correction Code (ECC), Adaptive Thermal Protection, Redundant Array of Independent NAND, Multistep Data Integrity Algorithm, Active Garbage Collection, dynamic write acceleration, power loss data protection, Autonomous Power State Transition (APST), S.M.A.R.T.
- 22 mm x 80 mm
- 5-year warranty
- Capacity
- 250 GB
- Form Factor
- M.2 2280
- Interface
- 22 mm
- 80 mm
Performance
- SSD Endurance
- 150 TB
- Internal Data Rate
- 2100 MBps (read) / 1150 MBps (write)
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
- Compatible Bay
- M.2 2280
- Software Included
- Acronis True Image
- UL, TUV, VCCI, BSMI, FCC, WEEE, ICES, KC, China RoHS, RCM, Morocco
- Limited warranty - 5 years
- 0 °C
- 70 °C
