Make your computer faster and more efficient with the Crucial MX200 SSD, which delivers the industry’s best balance of performance, endurance, and efficiency. Leveraging leading specs on all fronts, along with the Dynamic Write Acceleration technology, the Crucial MX200 is loaded with innovative features and immediately increases your system’s performance. With sequential reads up to 555 MB/s and an endurance rating that’s up to 5 times greater than a typical client SSD, the Crucial MX200 is engineered to never let up.
- Crucial MX200 - solid state drive - 500 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 500 GB
- Hardware Encryption
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- M.2 2280
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- TRIM support, Error Correction Code (ECC), Power Loss support, Adaptive Thermal Protection, Microsoft eDrive compatible, Redundant Array of Independent NAND, Active Garbage Collection, Extreme Energy Efficiency technology, Data Path Protection, dynamic write acceleration, Exclusive Data Defense, S.M.A.R.T., 256-bit AES, IEEE 1667
- 22 mm x 80 mm
- Microsoft Certification
- Compatible with Windows 7
- 3 years warranty
- Capacity
- 500 GB
- Form Factor
- M.2 2280
- Interface
- SATA 6Gb/s
- 22 mm
- 80 mm
Performance
- SSD Endurance
- 160 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 555 MBps (read) / 500 MBps (write)
- 4KB Random Read
- 100000 IOPS
- 4KB Random Write
- 87000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - M.2 Card
- Compatible Bay
- M.2 2280
- UL, TUV, VCCI, C-Tick, BSMI, IC, FCC, RoHS, KCC, WEEE
- Limited warranty - 3 years
- 0 °C
- 70 °C
