Today's data deluge requires a revolutionary way to mine data for insights and turn insights into action. Created to radically accelerate data center applications and workloads, the Micron 9200 series of SSDs combines the capacity of 3D NAND with the proven throughput and response times of the NVM Express (NVMe) protocol to deliver one of the most complete high-capacity, high-performance solutions available. Maximize application throughput and minimize latencies to get faster access to your data - and a powerful business advantage. Available in the U.2 and HHHL form factors in capacities from 1.6TB to 11TB.
Accelerate your applications
Accelerate the transformation of data into business value and provide a higher level of service to your customers with transfer speeds up to 5.5 GB/s and read IOPS up to 900K. -
Large and in charge
With capacities up to 11TB, the Micron 9200 SSD satisfies the most storage-hungry use cases in about one quarter of the rack space of 2D NAND. -
Unlock the value of your data transfer
Using the fastest of all SSD interfaces, the Micron 9200 family of high-performance NVMe drives accelerates applications on demanding workloads. -
Optimize your existing infrastructure
Deliver bottom-line value and efficiency to business and IT operations with Micron's high-performance flash solutions in industry-standard capacities up to 11TB. -
Get peace of mind with solid data protection
Ensure data integrity with the Micron 9200 SSD's full enterprise end-to-end data path protection, power-loss protection, and secure signed firmware.
- Micron 9200 ECO - SSD - 11 TB - U.2 PCIe 3.0 (NVMe)
- Solid state drive - internal
- Capacity
- 11 TB
- NAND Flash Memory Type
- 3D triple-level cell (TLC)
- Form Factor
- 2.5" SFF
- Interface
- Heat-resistant, End-to-end data path protection, power loss data protection, cyclic redundancy checks (CRC), S.M.A.R.T.
- 69.85 mm x 100.5 mm x 15 mm
- Capacity
- 11 TB
- Form Factor
- 2.5" SFF
- Interface
- 69.85 mm
- 100.5 mm
- 15 mm
Performance
- SSD Endurance
- 16.1 PB
- Internal Data Rate
- 3.35 GBps (read) / 2.4 GBps (write)
- 4KB Random Read
- 800000 IOPS
- 4KB Random Write
- 95000 IOPS
- Average Latency
- 0.03 ms
Expansion & Connectivity
- Compatible Bay
- 2.5" SFF
- Power Consumption
- 25 Watt (active) , 8 Watt (idle)
- EN 60950, IEC 60950, EN55024, EN55022 Class B, FCC, RoHS, UL 60950-1 Second Edition, AS/NZS CISPR22:2008 Class B, WEEE 2012/19/EC, CNS 13438 Class B, KN32 Class B, ICES-003:2016 Class B, KCC KN35
- 0 °C
- 70 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
- 25 - 95% (non-condensing)
