Crucial Micron 5200PRO 960GB SATA 2.5"
Quicklinx: DDF0WS00 Mfr#: MTFDDAK960TDD-1AT1ZABYY
Form Factor: 2.5"
Capacity: 960GB
Interface: Serial ATA-600
Type: Internal hard drive
£135.84 ex VAT
£163.00 inc VAT
There’s an easy way to speed up business-critical workloads that cripple hard drives: The Micron® 5200 series of SATA SSDs. Engineered on industry-leading 64-layer 3D NAND, the Micron 5200 SSD delivers best-in class performance and capacity on the same proven architecture as the 5100 series. Designed for virtualized workloads that power your business, such as OLTP, BI/DSS, VDI, block/object, media streaming and more, the lowlatency Micron 5200 series of SSDs eliminates storage bottlenecks with fast, consistent performance – and a lower total cost of ownership. A single Micron SSD allows you to get 3X more performance than an entire rack of 24 10K RPM hard drives. Imagine the impact — across your entire data centre.
  • Better all-around performance
    Get better storage performance and better business performance. A single Micron SSD enables 3X more performance than an entire rack of 24 hard drives. Imagine the impact - across your entire data center.
  • Fewer servers to accomplish more
    Improve efficiency in virtualized, hyper-converged and software-defined storage environments through server and storage platform consolidation and simplified IT maintenance, and improve TCO with lower power, cooling, software licensing and co-location costs.
  • Storage that scales
    Save time and money. The unique Flex Capacity feature allows you to adjust the drive's endurance, performance and capacity to meet your changing storage needs as your business grows and your workload and application needs evolve.
Micron 5200 PRO - solid state drive - 960 GB - SATA 6Gb/s
Solid state drive - internal - Native Command Queuing (NCQ), Dynamic and Static Wear Leveling, Secure Erase function, Enhanced Power Loss Data Protection, Multi-Word DMA mode 0-2 support, Ultra DMA Mode 0-6 support, PIO mode 3, 4 support, End-to-end data protection, Hot-Plug Support, upgradable firmware
960 GB
NAND Flash Memory Type
3D triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), Dynamic and Static Wear Leveling, Secure Erase function, Enhanced Power Loss Data Protection, Multi-Word DMA mode 0-2 support, Ultra DMA Mode 0-6 support, PIO mode 3, 4 support, End-to-end data protection, Hot-Plug Support, upgradable firmware, S.M.A.R.T.
69.85 mm x 100.45 mm x 7 mm
70 g
960 GB
2.5"
SATA 6Gb/s
Bytes per Sector
512
69.85 mm
100.45 mm
7 mm
70 g
Performance
SSD Endurance
2270 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 520 MBps (write)
4KB Random Read
95000 IOPS
4KB Random Write
32000 IOPS
Reliability
MTBF
3,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
1.5 Watt (idle) , 3.6 Watt (sequential write) , 2.8 Watt (sequential read)
BSMI CNS 13438 Class A, RoHS, NMB-3 Class A, AS/NZS 60950-1 Second Edition, IEC 60950-1:2005 Second Edition, FCC CFR47 Part 15 A, IEC60950/EN60950, WEEE 2012/19/EC, EN 55032 Class A, KCC KN32 Class A, VCCI V-3/2015.04 Class A, KN35 Class A, Micron Green Standard, BSMI CNS 15663, ICES-003:2016, AS/NZS CISPR32 Class A, EN 60950-1:2006 + A11:2009 + A1:2010 + A12:2011 + A2:2013
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
5 - 95%
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (non-operating)
3.13 g @ 5-800 Hz
Form Factor: 2.5"
Capacity: 960GB
Brand: Crucial
Price Range Ex VAT: 100 - 150
