There’s an easy way to speed up business-critical workloads that cripple hard drives: The Micron® 5200 series of SATA SSDs. Engineered on industry-leading 64-layer 3D NAND, the Micron 5200 SSD delivers best-in class performance and capacity on the same proven architecture as the 5100 series. Designed for virtualized workloads that power your business, such as OLTP, BI/DSS, VDI, block/object, media streaming and more, the lowlatency Micron 5200 series of SSDs eliminates storage bottlenecks with fast, consistent performance – and a lower total cost of ownership. A single Micron SSD allows you to get 3X more performance than an entire rack of 24 10K RPM hard drives. Imagine the impact — across your entire data centre.
Fewer servers to accomplish more
Improve efficiency in virtualized, hyperconverged and software-defined storage environments through server and storage platform consolidation and simplified IT maintenance, and improve TCO with lower power, cooling, software licensing and co-location costs. -
Storage that scales
Save time and money. Flex Capacity feature allows you to adjust the drive's endurance, performance and capacity to meet your changing storage needs as your business grows and your workload and application needs evolve.
- Micron 5200 ECO - SSD - 1920 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 1920 GB
- NAND Flash Memory Type
- 3D triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Native Command Queuing (NCQ), Dynamic and Static Wear Leveling, Secure Erase function, Enhanced Power Loss Data Protection, Multi-Word DMA mode 0-2 support, Ultra DMA Mode 0-6 support, PIO mode 3, 4 support, End-to-end data protection, Hot-Plug Support, upgradable firmware, S.M.A.R.T.
- 69.85 mm x 100.45 mm x 7 mm
- 70 g
- Capacity
- 1920 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Bytes per Sector
- 512
- 69.85 mm
- 100.45 mm
- 7 mm
- 70 g
Performance
- SSD Endurance
- 3500 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 540 MBps (read) / 520 MBps (write)
- 4KB Random Read
- 95000 IOPS
- 4KB Random Write
- 22000 IOPS
Reliability
- MTBF
- 3,000,000 hours
- Non-Recoverable Errors
- 1 per 10^17
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 1.5 Watt (idle) , 3.6 Watt (sequential write) , 3 Watt (sequential read)
- BSMI CNS 13438 Class A, RoHS, NMB-3 Class A, AS/NZS 60950-1 Second Edition, IEC 60950-1:2005 Second Edition, FCC CFR47 Part 15 A, IEC60950/EN60950, WEEE 2012/19/EC, EN 55032 Class A, KCC KN32 Class A, VCCI V-3/2015.04 Class A, KN35 Class A, Micron Green Standard, BSMI CNS 15663, ICES-003:2016, AS/NZS CISPR32 Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- 0 °C
- 70 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
- 5 - 95%
- Shock Tolerance (non-operating)
- 1500 g @ 0.5 ms
- Vibration Tolerance (non-operating)
- 3.13 g @ 5-800 Hz
