Crucial Micron 1100 512GB SATA M.2 Client SSD
Quicklinx: DFFCWS00 Mfr#: MTFDDAV512TBN-1AR12ABYY
The 1100 SATA SSD provides exceptional performance and extremely low power consumption for client computing applications ranging from desktop gaming rigs to corporate road warrior tablets. The 1100 SSD is manufactured to excel in performance, endurance, price and power while enabling green computing. Device sleep (DEVSLP) low-power modes extend battery life, and several features protect valuable data, including Opal 2.0 self encryption, power-loss protection for data-at-rest and adaptive thermal monitoring.
  • Enhanced durability
    With an MTBF of 1,500,000 hours, this solid state drive offers reliability and durability for users who demand performance over time. Its robust shock and vibration tolerance ensures your data remains safe even in non-operating conditions, making it an ideal choice for users who value data integrity.
  • High-speed performance
    Experience swift data transfer with internal data rates of up to 530 MBps for reading and 500 MBps for writing. Coupled with a 4KB random write of 83,000 IOPS, this drive is designed to handle intensive tasks efficiently, providing a seamless computing experience.
  • Low power consumption
    Featuring DEVSLP SATA low power mode, this solid state drive is engineered for efficiency. It reduces power consumption without sacrificing performance, making it an excellent choice for users looking to enhance their system's energy efficiency.
  • Advanced compatibility
    Microsoft eDrive compatible and equipped with a Serial ATA-600 interface, this drive offers versatile compatibility and easy integration into existing systems. Its adherence to several compliant standards including S.M.A.R.T. ensures a reliable and secure storage solution.
Micron 1100 - SSD - 512 GB - SATA 6Gb/s
Solid state drive - internal
512 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
16nm 3D triple-level cell (TLC)
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), Device Initiated Power Management (DIPM), Secure Erase function, Adaptive thermal monitoring, DEVSLP SATA low power mode, Microsoft eDrive compatible, Multi-Word DMA mode 0-2 support, Ultra DMA Mode 0-6 support, PIO mode 3, 4 support, dynamic write acceleration, S.M.A.R.T.
22 mm x 80 mm
512 GB
Hardware Encryption
256-bit AES
M.2 2280
SATA 6Gb/s
Bytes per Sector
512
22 mm
80 mm
Performance
SSD Endurance
240 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
530 MBps (read) / 500 MBps (write)
4KB Random Read
92000 IOPS
4KB Random Write
83000 IOPS
Average Latency
40 µs
Reliability
MTBF
1,500,000 hours
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
55 mW (idle) , 70 mW (active) , 2 mW (sleep) , 4000 mW (maximum)
TUV, RRL, ICES-003 Class B, IC, RoHS, UL 60950-1 Second Edition, KCC, WEEE, BSMI CNS 13438, FCC CFR47 Part 15 B, RCM, VCCI V-3/2011.04, Directive 2012/19/EC, OPAL 2.0, IEC60950/EN60950, IEEE 1667, KN32, KN35, EN 55032 Class B, ATA-8 ACS3, AS/NZS CISPR 32 Class B
70 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (non-operating)
3.1 g @ 5-800 Hz
