Crucial DDR4 - 4 GB - DIMM 288-pin
Quicklinx: DQDRWS00 Mfr#: CT4G4DFS8266
The Crucial 288-pin are used in 4GB DDR4 memory for desktop computer and also DDR4 is the latest generation of memory with an improved architecture that allows it to transmit data more quickly. A dual inline memory module consists of a number of memory component that are attached to a printed circuit board. The gold pins on the bottom provide a connection between the module and a socket on a larger printed circuit board.
Crucial - DDR4 - module - 4 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - unbuffered
Memory module
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL19
Single rank, unbuffered
Voltage
1.2 V
Limited lifetime warranty (Germany - 10 years)
4 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL19
Non-ECC
Module Configuration
512 x 64
Chips Organization
X8
Voltage
1.2 V
