Crucial 8GB DDR4 2666 MHz SODIMM CL19 Memory
Quicklinx: G1FHWS00 Mfr#: CT8G4SFRA266
Type: DDR4 SDRAM
Connection: SO-DIMM 260-pin
Speed: 1333MHz
Data Integrity: Non-ECC
Registered/Buffered: Unbuffered
£16.04 ex VAT
£19.24 inc VAT
There's an easy cure for a slow computer: more memory. Designed to help your system run faster and smoother, Crucial Laptop Memory is one of the easiest and most affordable ways to improve your system's performance. Load programs faster. Increase responsiveness. Run data-intensive applications with ease, and increase your laptop's multitasking capabilities.
Crucial - DDR4 - module - 8 GB - SO-DIMM 260-pin / PC4-21300 - unbuffered
Memory module
8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2666 MT/s (PC4-21300)
Latency Timings
CL19
Single rank, unbuffered
Voltage
1.2 V
Limited lifetime warranty (Germany - 10 years)
8 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL19
Non-ECC
Voltage
1.2 V
Type: DDR4 SDRAM
Speed: 1333MHz
CAS Latency: CL19
Standard: PC4-21300
Brand: Crucial
