Crucial 8GB DDR2 667MHz (PC2-5300) CL5 240 Pin
Quicklinx: 7BSBWS00 Mfr#: CT102472AF667
Enterprise-level performance. Tested, qualified, and reliable, Crucial server memory delivers enterprise-level performance. Crucial server memory is available in LRDIMM, FBDIMM, RDIMM, and unbuffered ECC module types. With a wide variety of speeds and densities to choose from, Crucial server memory is designed to meet the needs of server platforms and operating systems, both new and old. Trust Crucial memory for your server and workstation applications, and keep your important data running smoothly.
Crucial - DDR2 - module - 8 GB - FB-DIMM 240-pin - 667 MHz / PC2-5300 - Fully Buffered
Memory module
8 GB
Memory Type
DDR2 SDRAM - FB-DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Fully Buffered
Voltage
1.8 V
Lead Plating
Gold
Kingston KVR667D2D4F5/8GI, Kingston KVR667D2Q4F5/8G, Crucial MT36HTS1G72FY-667A1D4, Crucial MT36HTS1G72FY-667A1D6, Crucial MT72HTS1G72FY-667G1D6, HP 398709-071, HP 413015-S21, Kingston KVR667D2D4F5/8G
8 GB
Upgrade Type
Generic
DRAM memory module
DDR2 SDRAM
FB-DIMM 240-pin
Module Height (inch)
1.18
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
ECC
Fully Buffered
Module Configuration
1024 X 72
Voltage
1.8 V
Lead Plating
Gold
RoHS
