Crucial 750GB MX300 2.5" 7mm SATA 6Gb/s SSD
Quicklinx: C2KVWS00 Mfr#: CT750MX300SSD1
Increase the speed, durability, and efficiency of your system for years to come with the Crucial MX300 SSD. Boot up in seconds and fly through the most demanding applications with an SSD that fuses the latest 3D NAND flash technology with the proven success of previous MX-series SSDs. Your storage drive isn't just a container, it's the engine that loads and saves everything you do and use. Get more out of your computer by boosting nearly every aspect of performance.
Crucial MX300 - SSD - 750 GB - SATA 6Gb/s
Solid state drive - internal
750 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, hardware encryption, Error Correction Code (ECC), Adaptive Thermal Protection, Redundant Array of Independent NAND, Multistep Data Integrity Algorithm, Active Garbage Collection, Extreme Energy Efficiency technology, Data Path Protection, dynamic write acceleration, power loss prevention (PLP), Marvell 88SS1074 controller, Crucial Custom Firmware, Device Sleep support, S.M.A.R.T.
7 mm
3-year warranty
750 GB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
7 mm
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
530 MBps (read) / 510 MBps (write)
4KB Random Read
92000 IOPS
4KB Random Write
83000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Software Included
Acronis True Image HD
2.5mm mounting spacer
UL, TUV, VCCI, C-Tick, BSMI, FCC, RoHS, KCC, WEEE, China RoHS, SATA-IO, IEEE 1667
Limited warranty - 3 years
70 °C
